Results 1 to 10 of 13
Thread: EFI Fuel Tank for 4age Conversion
    Senior Member eastcoastdrifter's Avatar
    Iain C
    Default EFI Fuel Tank for 4age Conversion
    I know I have asked this a million times (so have a million others probably) but when it comes to a 4AGE what options are there when it comes to converting your fuel tank/pump to handle the extra pressure needed? what other model cars tanks can be retrofitted? I was at Mx5Mania Today and thinking maybe a NA6 one??...
    The More info the better answers it will help others I think haha..
    How many times have you seen kids playing on the Touge at night.
    Ae82 pump in your ae86 tank works well. Vl lift pump and external pump also works. If you have loads of cash buy a jdm tank for what I consider stupid money.
    Wiring the tank is easy for an internally mounted pump. Bulkhead wiring connectors so the ffuel doesn't run run through the insulation.
    Sure the tank doesn't have regular efi baffles but you'll rarely get surge.
    Jake
    Northgate
    if you keep std tank can get fuel grade foam that you put in fuel cell's
    ryan
    Best bet leave your original tank and just mod it to suit. Use either a Vl in tank pump fitted to your in tank pipes or alternatively an external lift pump( reason I say this is because I've had trouble with my Vl fuel pump slipping off it's pipe). It would be best to run a surge tank if your going to be drifting it, but alot of people don't. You can get away with out a surge tank if you makesure you don't go below a quarter if a tank, cause that's when fuel surge is Likley to happen.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    I am still to looke but i think something like a VT fuel pump(intank) could work very well, as it has a swell pot and everything all in 1, so instead of needing surge tank or baffles
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    Quote Originally Posted by lolwat View Post
    this, shameless plug here - buy the one I'm selling
    BENT MECHANIX - Garage 20:
    Aug 2010
    Geoff
    mt dandenong
    Quote Originally Posted by NIZLAH View Post
    i just got given one, going to see if i can get it to fit/work in a ke70 wagon fuel tank.
    did i read somewhere you can mod a s13 tank to fit a ae86?
    Michael
    Crimebrook 2749
    keep in mind old ones, the swell pot falls apart, get it alot in VT's go around corner and it dies (low fuel level), BOOM 150 bucks new pump and assembly
    Jake
    Northgate
    $150 for new pump and assy is alright really compared to buying a JDM tank.
    Veteran anastasios's Avatar
    Taz
    Earlwood
    i use jdm tank in my 71 with a bigport, no issues with surge
  1. WTB, AE86 JDM style Fuel tank ( as in EFI Tank )
    By Lexsmaz in forum Cars or Parts Wanted
    Last Post: 1st August 2010, 10:20 AM
  2. EFI fuel tank
    By Jonny Rochester in forum Cars or Parts Wanted
    Last Post: 21st July 2008, 10:00 AM
  3. JDM EFI fuel tank
    By bart in forum Cars or Parts Wanted
    Last Post: 16th June 2008, 10:41 AM
  4. help - efi tank conversion...
    By sprintrphile in forum Technical - Questions
    Last Post: 15th May 2006, 08:49 PM
