Results 1 to 6 of 6
Thread: SC14, Modded GZE SC12 Mount, AE101 Smallport GZE intake 3SGTE throttle body, Modded AE92 GZE ECU
    Mar 2011
    Ali
    Default SC14, Modded GZE SC12 Mount, AE101 Smallport GZE intake 3SGTE throttle body, Modded AE92 GZE ECU
    For Sale.
    SC14 off a 1GGZE, has been modified to suit SC12 GZE lower bracket
    - Comes with stripped SC12 and 750ml bottle of new supercharger oil
    SOLD
    GZE SC12 Mount
    - Modded to suit SC14 and line up stock SC14 pulley with crank
    SOLD
    AE101 Smallport GZE intake with 3SGTE throttle body,
    Mod done by either professional, or someone with skills.
    SOLD
    The TPS Plug is damaged on one side, be a wreckers job, or you can try aftermarket.
    I will include it so you know what your looking for, but don't use it, its fubar.
    The other sensor that's on there, I can cut off the loom for you.
    Modified AE92 Smallport GZE ECU - Suit AE101 Loom
    Withdrawn
    Has been internally modified to suit AE101 Loom
    New capacitors have been installed
    This was used on a 16V AE101 Smallport GZE with SC12 running 11psi that used a Supra knock senor.
    The reason behind this is due to the knock issue the AE101's have, the AE92 didn't suffer it near as bad and when used in conjunction with the supra knock sensor it reduces issue even further.
    Stock AE101 top mount GZE intercooler with cover
    SOLD
    Will swap for RWD T2 16V exhaust manifold, smallport RWD intake plenum, aftermarket programmable ECU, front mount for a KE70...or something useful along these lines.
    All prices not including freight.
    Will freight interstate.
    Got a bunch of random AE101 gear from half cut,
    E58 GZE FWD gearbox and CV shafts SOLD
    FWD Engine mounts SOLD
    ask the question if you need something.
    PM or Msg
    0468371779
    Ali.
    Mar 2011
    Ali
    Prices are negotiable.
    Mar 2011
    Ali
    Pictures up
  • #4
    Mar 2011
    Ali
    Make an offer, you never know.
  • #5
    Mar 2011
    Ali
    Bump
  • #6
    Mar 2011
    Ali
    SC14 and mount SOLD.
  • Similar Threads
    1. [vic] 4AGZE Alternator, 365cc Injectors, AE101 GZE ecu
      By GZE016 in forum Car Parts For Sale
      Last Post: 3rd June 2012, 10:18 PM
    2. Replies: 5
      Last Post: 15th November 2011, 06:24 PM
    3. Replies: 4
      Last Post: 2nd January 2011, 10:30 PM
    4. Replies: 18
      Last Post: 1st October 2009, 06:39 PM
    5. Throttle Body Position (gze)
      By slide86 in forum Technical - Questions
      Last Post: 11th May 2006, 10:00 AM
