Results 1 to 10 of 11
Thread: correct ae86 rear quarter glass fitment and recommended alloy radiator purchase
    Aug 2012
    jason
    qld
    ipswich
    Default correct ae86 rear quarter glass fitment and recommended alloy radiator purchase
    Going to paint my ae86 soon and im going to remove rear quarter glass. i can see its been pulled out and reinstalled before but doesnt look right. anyone have a explanation on what sealant to use and how to do it properly would be greatly apprieciated. im also looking at getting an alloy radiator and on ebay you can purchase rads anywhere from china examples for 137 up to koyo at 600. what have you guys used and reccomend to buy or if you know a good brand and supplier please let us know.
    I've bought from this guy and had no issues
    http://www.ebay.com.au/itm/52mm-alum...item4603db186b
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    ASI radiators off ebay, lots of people run them and there cheap, havent had an issue with mine
    Adan
    Oxley Park
    Yep I run the same one too, never had any problems in a number of cars..
    If you can take the window trim off, youre more than skilled enough to take out the window. If you have the screw in window securing doovies, almost any silicone adhesive product will do the job.
    I used Simson adhesive, but your sika products, bond and seal, bostik etc will work fine too...
    Aug 2012
    jason
    qld
    ipswich
    Thanks for feedback much apprieciated
    Member _sawyer_'s Avatar
    Feb 2010
    Paul
    West melbourne
    I tried the asi one and it fitted like shit, the lower and upper mounts were in the wrong spot. Are there any suggestions for a 2row aftermarket copper core rad?
    Aug 2012
    jason
    qld
    ipswich
    Damm i was to purchase a asi one too. is there any chance there are different mounting points between models like levin to trueno etc.
    Adan
    Oxley Park
    how far were they wrong?
    Ive had a few with the mounts welded on a bit crooked, but nothing worth complaining about.
    If it doesnt fit, send it back and get another one....
    Aug 2012
    jason
    qld
    ipswich
    I just bought a asi radiator. i had to trim the bracket down which connects the top and bottom taks of the rad as it wouldnt fit in the gap of the rad support panel. then i notived thst the bottom rad tank sits hard against the lower rad support panel so ill have to get the lower mount pins cut off and welded into the correct position. cheap radiator cheap quality
    West
    If high quality was important then you should have bought a Koyorad.
    Anyhow, most after market aluminium radiators are pretty iffy. The zz one I had allowed the factory thermo fans to bolt up, but with a half inch gap all the way around, rendering them useless in that application.
  1. right rear quarter glass outer trims wanted
    By terryo in forum Cars or Parts Wanted
    Last Post: 27th December 2012, 01:29 PM
  2. Replies: 0
    Last Post: 7th December 2012, 08:32 PM
  3. rear quarter glass. for ae86 hatch
    By Danny t in forum Cars or Parts Wanted
    Last Post: 23rd October 2010, 11:58 PM
  4. wtb ae86 coupe rear quarter glass.
    By steroidchickens in forum Cars or Parts Wanted
    Last Post: 9th January 2010, 11:35 AM
  5. WTB ae86 rear-quarter glass
    By D86TOY_20V!nce in forum Cars or Parts Wanted
    Last Post: 26th June 2008, 10:55 AM
