Results 1 to 9 of 9
Thread: JDM T series rear caliper rebuild
    Senior Member sheppo's Avatar
    Sep 2011
    Karl
    Hallett Cove
    Default JDM T series rear caliper rebuild
    Car - KE70
    motor / part in question - Rear Brake Calipers
    problem - Seals split and need replacing
    occurs/started when (if applicable)- when I pulled the diff apart after it arrived from qld
    personal situation (if applicable)- confused?
    So I recently acquired a t series LSD disc to disc rear end. I'm in the process of cleaning it up and replacing brake parts before fitting it to the car.
    After pulling the calipers off the diff I've discovered a couple of the seals have split and need replacing.
    Dave from AJPS has said that he can supply me with new seal kits. I've pulled the main piston out of the calipers but can't see how the main seal is kept in? There seems to be a metal ring holding it in place but there it doesn't seem to be a circlip?
    Just wondering if anyone has pulled these apart before and has any advice in how to go about this?
    Senior Member dansomerville's Avatar
    Jun 2011
    Daniel
    Townsville
    I did mine with seal kits from Dave not to long ago.
    There is no circlip for the seals, just a metal ring that holds them in.
    The ring has a split In it, so it's not a complete circle.
    I just used a small screw driver to pop and twist it out, and the same for putting back in, just being careful not damage the seal itself.
    The big issue with the rear calipers is that thread that the piston screws on to.
    There's a circlip in there that requires you to compress the spring to get it back in. And because that thread is an odd pitch you can try and try like I did but you need a special tool from Toyota to put it back in.
    I got the shits and took them around to heaps of brakes places and they all said they had no idea how they'd put them back together, so I ordered the tool from Toyota, lucky enough they had one in stock, still took a month to get to me.
    This probably isn't all that clear, sorry. Get a hold of the workshop manual and it makes it much clearer.
    Veteran Rice86's Avatar
    Richard
    Liverpool
    the piston re-install pissed me off, I didn't rebuild mine which i should of had at the time..
    But anyways I had to take the piston out to inspect wtf was going on as it wouldn't screw in while doing a brake pad change, it is possible to screw the piston back without some special tool just FYI as I did it on my own, just a lot of rage and swearing and force once it screws onto the thread it should screw in again as normal..
    dose
    Jun 2011
    Daniel
    Townsville
    The piston isn't the hard part to put back in, it should just screw down on to that thread.
    You need the tool when you take them right apart, you have to compress that spring to get a circlip back in inside the housing. It's gay as aids.
    Sep 2011
    Karl
    Hallett Cove
    Gay! Well I guess I'm gonna have to try and do it with out the special tool!!
    Thanks for the advice fellas I'll let you know how I go!!
    Member geoff's Avatar
    Geoff
    Glen Waverley
    Quote Originally Posted by dansomerville View Post
    Haven't done it in an ae86 but have done it in an aw11. A quick search on toyodiy says the spring and retainer are the same part number.
    I did it without the sst. You can compress the spring using a cable tie and then after getting the circlip back in, cut the cable ties and fish them out with pliers. Had to resort to this because toyota said it'd take a month to get the sst in.
    one on the left
    Also you should buy one of those cube caliper unscrew tool things from super cheap auto. In my experience, they do not unwind with needle nose pliers
    Jun 2011
    Daniel
    Townsville
    Haha yes this is what I tried to do also but could never make it work, I lost my shit at it and just ordered the tool.
    Sep 2011
    Karl
    Hallett Cove
    Okay thanks again guys!!
    Yeah that cable tie idea looks good in theory but I'll see when I give it a go!!
    Cheers!
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    doing this at the moment, glad I stumbled in and noticed the need to compress the spring before replacing the circlip, would have done my head in..
    BENT MECHANIX - Garage 20:
  1. AE86 JDM Caliper Rebuild Kits
    Last Post: 18th February 2014, 07:13 AM
  2. AE86 JDM Caliper Rebuild Kits
    By sc86 in forum SC Auto Parts
    Last Post: 13th November 2013, 03:48 AM
  3. Parts for Rear JDM caliper rebuild!
    By haydenz in forum Technical - Questions
    Last Post: 25th August 2010, 12:57 AM
  4. JDM Rear Caliper rebuild kit
    By haydenz in forum Cars or Parts Wanted
    Last Post: 12th February 2010, 12:43 AM
  5. JDM caliper rebuild
    By robert nguyen in forum Technical - Questions
    Last Post: 5th June 2007, 09:16 PM
