Car - KE70
motor / part in question - Rear Brake Calipers
problem - Seals split and need replacing
occurs/started when (if applicable)- when I pulled the diff apart after it arrived from qld
personal situation (if applicable)- confused?
So I recently acquired a t series LSD disc to disc rear end. I'm in the process of cleaning it up and replacing brake parts before fitting it to the car.
After pulling the calipers off the diff I've discovered a couple of the seals have split and need replacing.
Dave from AJPS has said that he can supply me with new seal kits. I've pulled the main piston out of the calipers but can't see how the main seal is kept in? There seems to be a metal ring holding it in place but there it doesn't seem to be a circlip?
Just wondering if anyone has pulled these apart before and has any advice in how to go about this?
