Page 11 of 11 FirstFirst ... 2 3 4 5 6 7 8 9 10 11
Results 101 to 110 of 110
Thread: sr20det ke70 - lots of pictures
  1. #101
    Feb 2012
    Jake
    Wanneroo
    The heavy duty clutch i was running started to give up so i bought a hhdb exedy clutch and picked up a blown rb25 box so have a play with while it was apart, seem too all fit in pretty well so ill look at rebuilding the box and replacing the 20 box in the future
  2. #102
    Veteran ae8zn6's Avatar
    Robbo
    Gippsland
    yeah, with the kind of numbers you are running you will likely need the bigger box... particularly with an aggressive clutch, but then again will also depend on the size tyres you are using and how aggressively you shift gears etc...
    Does the bellhousing really clear?
    In my car the bell is really the limiting factor by a long way, if I wanted to go to an rb25 box there would be a lot of cutting involved
    Current Cars:
  3. #103
    Feb 2012
    Jake
    Wanneroo
    Quote Originally Posted by ae8zn6 View Post
    its tight but will fit fine. moving the engine forward on the cross member has paid off a heap of times already.
  4. #104
    Feb 2012
    Jake
    Wanneroo
    put my new clutch in doesn't feel the best with a very high release point but im told these clutches can do weird things for the first 1000kms while they bed in so ill see how it goes
    also had another couple of rockers break on me
    had some hand brake issues so decided to strip the rear callipers down and do a quick clean and rebuild
    and also found that the crank breather between the bottom end and the rocker cover is suppose to have a restricter in it so i pulled it out of the original pipe and put it in the new one
  5. #105
    Feb 2012
    Jake
    Wanneroo
    Went to order harder rear springs and this happened
  6. #106
    Feb 2012
    Jake
    Wanneroo
    Gone solid lifters now
    Procam 260 solid profile (slightly smaller than the bc264s i had)
    And a bigger map sensor
    With some good results
  7. #107
    Oct 2015
    Reece
    Mackay
    wow i just read this from start to finish... good build man. has given me a few tricks for my build am going similar route (sr20det) very impressive mate.
  8. #108
    Feb 2012
    Jake
    Wanneroo
    For anyone interested this car is for sale,
    Toyota Corolla KE70 SR20DET Engineered on Gumtree http://www.gumtree.com.au/s-ad/11233...utm_source=sms
  9. #109
    Robbo
    Gippsland
    Did you ever end up fitting the 25 box?
    Just interested to know how much further back the shifter would be compared to a SR bell on a 20 box...
    Current Cars:
  10. #110
    Oldschool Member flower86's Avatar
    Sep 2007
    flo
    melbourne
    south dandy
    Yea would also like to know how you went with the 25box ?
  1. Replies: 6
    Last Post: 18th June 2010, 10:30 AM
  2. Ke70 lots of mods (SA)
    By sidewayz_70 in forum Cars for Sale (Toyota Only)
    Last Post: 18th June 2009, 10:53 AM
  3. LOTS OF KE70 PANELS VERY CHEAP
    By v-tec in forum Car Parts For Sale
    Last Post: 1st December 2007, 10:54 AM
  4. Pictures of Silver Ke70's
    By howee in forum Offtopic Discussions
    Last Post: 9th July 2007, 02:02 PM
Tags for this Thread
