Results 1 to 10 of 10
Thread: 4AGE FWD VS RWD sump differences
    Senior Member J0RD0's Avatar
    Feb 2010
    Jordan
    Default 4AGE FWD VS RWD sump differences
    Hi all, Im just wondering if there are any differences between the rwd and fwd sumps. As some of you know im doing 4age mounting kits and want to do a "lowered version" but currently the 4age im using for test fitting which i believe is a fwd motor has a sort of drop extention on the drivers side of the rear of the sump and is really close to the rack mount. I had the same problem when doing the evorolla, so without having to tell customers to bash or modify their sump's does the rwd sump have more clearances on both sides of the rear of the sump??? Or even the 4ac (wish i didnt throw my 4ac in the bin) have a different design and will it bolt up to a 4age??
    Oppinions and suggestions people's?
    THE EVOROLLA none of this SR shit . . . EVO 7 powered bitches
    https://www.facebook.com/KeConversions
    KE conversions - making your conversion simple
    4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
    Adan
    Oxley Park
    according to toyodiy, the ae92 4age and ae86 4age share the same part number for the sump, so Id say they are the same for all..
    Andrew
    East Melbourne
    Personally I've owned 4age bigport RWD and FWD, 4agze bigport and 4age smallport sumps.
    I've never noticed a difference except for an oil return for the factory coolers.
    FWIW JDM fwd's don't have the factory oil coolers....
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    smallports do
    Veteran timbo's Avatar
    Tim?
    Wild West
    Small ports here have them, so do some FWD 4a- f or c's.... So there is 4a sumps with no oil return, some with and then 7a & 20v have different sumps all together.
    Mar 2011
    Ali
    Last conversion I did was an AE86 RWD 4AC to FWD AE82 bigport
    I never really noticed the difference, went straight it, look the same to me.
    I take a closer look at my AE101 GZE sump, see if it varies and get some pictures for you.
    Ali
    Feb 2010
    Jordan
    Cheers man
    Eddie
    The only major difference you will get is between 16v and 20v. The 16v sump has an additional notch in the block and hence the sump. So you cannot interchange a 16v sump for a 20v sump without mods.
    Tim?
    Wild West
    The 20v has the notch.
  1. rwd or fwd 4age odds and ends
    By pen15 in forum Cars or Parts Wanted
    Last Post: 19th December 2010, 10:30 AM
  2. 4age fwd sump with oil return
    Last Post: 12th April 2009, 08:49 AM
  3. fwd to rwd 4age
    By stylz in forum Technical - Questions
    Last Post: 10th June 2008, 09:07 PM
  4. 4age fwd->rwd
    By noobae86 in forum Technical - Questions
    Last Post: 20th February 2007, 04:03 AM
  5. rwd coversion to fwd 4age
    By mish86 in forum Technical - Questions
    Last Post: 17th May 2006, 11:43 PM
