Results 1 to 10 of 13
Thread: please help best fitment for stock ae86 guards
    Aug 2012
    jason
    qld
    ipswich
    Default please help best fitment for stock ae86 guards
    Hey people about to purchase some rota grids for my ae86. I love the look of flush fitment but the car must suit its purpose. it has stock guards with the inners slightly rolled. im goin to be doing grip track and want offset that will just stay slightly in or flush with guards front and back. would a 15x8 0 offset be ok or is this slightly extreme. Will this clear lock to lock with no rubbing? Also Im running lowered king springs all round. Any feedback or pictures and recommended fitment sizes welcome. cheers jason.
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    15x8 +-0 will fit fine with rolled standard guards, however you will most likely need to figure out another way to mount the bumper where it meets the guard depending on what castor you run. What tyre size are you planning on using? Also king springs wont be much good if your tracking the car, far too soft.
    Moderator Frak's Avatar
    Jamie
    I run a 15x7 with 0 offset, fills standard guards nice, I have cusco lower control arms which are longer, they don't rub anywhere so all good.
    Hachiroku since 1994
    Veteran johl's Avatar
    Johl
    as james said, it will greatly depend on the size and type of tyre you want to run
    Veteran Rice86's Avatar
    Richard
    Liverpool
    15x8+0 195/50 will be about as much as you can get from stock guards, it will scrub onto things if your car is too low, the lower the more it will scrub from full lock to full lock
    15x7.5 - 5 would be perfect
    dose
    Veteran shift_rook's Avatar
    SE Burbs
    For actual time attack purposes i would say you'd want zero stretch, 15x7's with a 195/50 would be good.
    Veteran drift kid's Avatar
    Glossodia
    yeah as previously mentioned, 15x8 -+0 w/ 195/50 will fit perfectly flush w/ rolled guards
    Veteran timbo's Avatar
    Tim?
    Wild West
    I have 13x7 -0 with 205/60 which fit perfectly.
    Adam
    South Eastern
    i am pretty interested in this as well, want to run stock guards for a while so want wheels that fill the guards nicely,
    also previously i was running the stock 13" wheels for a while and the steering was quite light, went to 14's and the steering was alot heavier is this related to the diamater of the rim or possibly the tyre width?
    Mar 2011
    Mt Dandenong
    The increased steering weight would be related to tyre width and possibly more weight from the larger wheels.
  1. [sa] ae86 levin front guards. Stock. Rust free. Silver.
    By RyGuy86 in forum Car Parts For Sale
    Last Post: 25th September 2012, 03:47 AM
  2. Replies: 15
    Last Post: 28th July 2012, 01:32 AM
  3. Ae86 stock front guards nsw
    By timpy in forum Cars or Parts Wanted
    Last Post: 26th June 2012, 10:09 PM
  4. stock ae86 front guards and ae82 front guards
    Last Post: 5th February 2011, 12:51 AM
  5. do 15x10 fit under stock rolled guards on AE86?
    By AE86dori in forum Technical - Questions
    Last Post: 4th October 2008, 01:34 AM
