Results 1 to 8 of 8
Thread: Diff clunk?
    Seamus
    Milton
    Default Diff clunk?
    Hi guys,
    Over the last couple of track days/drives, my diff(?) has started to make a 'clunk' whenever i do a decent clutch-kick, or if i do a really fast gearchange. If you've driven a nissan before, it's nearly exactly the same as that subframe clunk you get with them.
    My diff does whine a bit - but always has, and hasn't gotten noticeably worse recently. Google says the backlash could be off, or that trailing arm bushes could be flogged. Are there any other possibilities?
    THanks
    Seamus
    ^ Clicky clicky!
    Veteran timbo's Avatar
    Tim?
    Wild West
    I've had varying clunks from my diff... I had whiteline adjustable top trailing arms that shagged the thread so that between the frame and diff there was an immense amount of play, thus a clunk. Also I have a TRD 2-way which makes some noise, but it has always done this.
    If it is on hard throttle or even highway speed throttle blips and clunks, I'd check all you trailing arms and bushes and while the car is up check the backlash. Even with the wheel on you should be able to tell if there's a problem.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    drive along, say around 70-80 in 2nd-3rd(gear where you can play with the throttle a bit) on and off the throttle, and see how hard you actually have to load it up to get it to do it
    Jason
    Gold Coast
    you would think a backlash noise would happen at pretty much any speed when first getting on the throttle not just a clutch kick, I'm thinking a trailing arm bush.
    Veteran slide86's Avatar
    Huw
    Hills
    tailshaft hitting the floor?
    Seamus
    Milton
    I can't seem to get the noise to happen just on accel/decel, just fast gearchanges and clutch-kicks.
    Getting under the car, theres some freshly exposed metal on the tunnel above the nose of the diff/end of the tailshaft. Also, the TOP trailing arm bushes seem to be pretty/very crap (i can twist them and get deflection with a small screwdriver).
    My ride height hasn't really changed at all - so have the top arms deteriorated enough to make my diff hit? Is there anything else that would cause this?
    ^ Clicky clicky!
    Gone
    Joel
    Picton
    if it was a worn CW/P you could get it to slap at any time..
    id look at all the rear end bushes including the panhard.
    nothing really else back there that can cause movement with that kind of effect.
    Tim?
    Wild West
    If there's scrapes where you say above the diff housing it will most likely be the trailing arm bushes. The diff housing hits the top of the tunnel, so you might even need some ajustable arms to set pinion angle.
  1. Wtb adm sprinter diff, diff centre or crown and pinion.
    By Ade_Mc in forum Cars or Parts Wanted
    Last Post: 31st July 2012, 12:00 AM
  2. T. Series diff 4.11 diff gears, ae86 bolt in half cage
    By armc89 in forum Car Parts For Sale
    Last Post: 25th June 2012, 09:47 AM
  3. Diff Clunk
    By timbo in forum Technical - Questions
    Last Post: 3rd November 2010, 11:06 PM
  4. Clunk on front right corner when braking in reverse
    By pope in forum Technical - Questions
    Last Post: 23rd April 2008, 09:26 PM
