Results 1 to 7 of 7
Thread: SA: > R31, R30, volvo, B&M, audioline, amp, sumitomo, springs, also custom exhausts
    andrew
    prospect
    Default SA: > R31, R30, volvo, B&M, audioline, amp, sumitomo, springs, also custom exhausts
    Items in SA
    14X7 5 stud rims 0off with 215-65 tyres @ 80% even to suit torana/volvo or similar stud pattern $200
    R31 left and right 28 spline axels $20 each
    L24E engine and auto trans + pump 170,000 $150
    R30 170,000k dash cluster $50
    2X 225-50-R16 bridgestone G3 tyres with 60% even no camber use $50
    2X 225-50-R16 falken semi slicks 40% even $50
    CA18det stainless exhaust mani to suit external gate, perfect cond (going back to internal) $200
    R30 low King springs front + pedders rear and after market Munroe shock absorbers (under 5k use) $150. (only 1 rear in pic)
    -1X B&M line locker for not destroying your brakes whilst spinning the rear wheels. $160 installed and rear brakes bled
    -R31 S3 tinted front indicators from front of this $20ono, $30 posted
    -JDM BLAZE universal alloy gearknob. baller knob. $60ono, $70 posted
    -audioline 6.5" split system 120W rms $150. cost $260 in mid 08' (blue kevlar cone)
    Whiteline Nissan bluebird 910 aftermarket front swaybar with linkages and bushes
    $150
    -Full wiring kit for amp with all wires $15
    -Pioneer Sub and pioneer compact box unsure of model 250wrms or over $75
    -response amp. 2X150wrms. only works in bridged mode $100 . (or 15" sub n amp for $180)
    -Some 2way amp, around 350wrms bridged (160wrms per channel normal) $60
    pair of rims with sumitomo 195-50-R15 tyres @ 70% 15X7 +20 clear r32 brakes easy. stealth as, or just remove paint with wax and grease remover to restore them. $350
    -pioneer 2way 6inch $35
    -Greddy catch can with oversized fittings and drain arrangement. $75
    R31 skyline/pintara with RB20 turbo back 3" mandrill bent Exhaust with muffler or side pipe option in stainless steel. System finishes before the differential. Muffler is Lukey race stainless series
    $350
    -Also can do 2.5" and 3" mandrel bent exhaust systems now as i have thrown 2k at a mig welder. 4" exhausts also possible as im doing one on my pintara. Price dependant on car but for 2.5" mandrel bent it will be approx (150-250 - pending design) no mufflers with 2 flanges. (cat/extractors back)
    also doing turbo back with separate screamers, etc
    doing intercooler piping in mild steel aswell. pm for quotes. design dependant on what owner wants.
    Senior Member 20v ae71's Avatar
    Dillon
    Athelstone
    those 5 stud 14x7's wouldn't happen to have 5x120 (HQ, BMW) stud pattern? if so consider them sold
    edit: torana/volvo are 5x108
    Dillon
    Athelstone
    also pretty interested in a 2.5'' exhaust for my ae71. 2.5'' from turbo dumper back, no mufflers, under the diff, 3 flanges (dump pipe, mid flange, rear after diff)
    Senior Member sly1300's Avatar
    Dan
    NorthEast
    any pics of 14x7 5 studders? 5 x 114?
    hoping for 5x114 stud pattern to fit ford/yota 5 stud.
    wouldnt mind stretching some skinny tyres on em and whitewalling them for my lo-lux.
    andrew
    prospect
    yep wrong pattern.
    different PCD.
    PM sent
    Hey mate are you doing the exhausts as a commercial setup because if you are you should be talking to admin first otherwise you could find your thread deleted.
    andrew
    prospect
    not really, just doing bits hear and there for people for cheap. basically to pay off the welder. lol
    i can be contacted on 0432 224 954 at any time
  1. ke70 & AE86 coupe parts 4sale all MUST GO & JDM diff & 16v
    By Y-B-NRVS in forum Car Parts For Sale
    Last Post: 27th November 2012, 10:09 AM
  2. [SA] Standard KE70 Seats & Rear Springs
    By eS22 in forum Cars or Parts Wanted
    Last Post: 30th October 2012, 02:01 PM
  3. Replies: 0
    Last Post: 13th December 2011, 10:55 PM
  4. Replies: 4
    Last Post: 30th May 2011, 10:33 PM
