Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
Thread: Overheating Smallport 4age AE71- Headgasket?
    Senior Member pauliee's Avatar
    May 2011
    Paul
    Wollongong
    Default Overheating Smallport 4age AE71?
    hey there guys,
    Car - AE71
    motor / part in question - Smallport 4age
    problem - Overheating
    I made a thread about a month ago, but it was for a somewhat different issue.
    The issue is im currently having is my smallport will gradually overheat. I can drive it hard, no issues, but on longer trips, (20-30) kilometres, it'll rise gradually. I read somewhere someone had issues with it getting hotter at high speeds, and plateauing at low speeds. I havent driven mine for a little while (off the road with broken tailshaft), but it does sort of rise steadily, and drop as it pleases.
    Im using a 35mm alloy radiator, as well as new genuine Toyota water pump and all new gaskets, new ae86 radiator piping, as well as tested Thermostat, and proper coolant.
    I got the motor locally, and the previous owner had done a full gasket replacement etc etc before putting it in his car. But following parting the car out, it sat as a spare for approx 2 years.
    So im in two minds at the moment, on one hand, im thinking about getting another radiator,
    (http://www.ebay.com.au/itm/52mm-2-Co...ht_2041wt_1165)
    one of those ^, because for not much less cost the 35mm radiator can be serviced. But im quietly concerned that it may not be the radiator, and there may be another issue with the motor.
    I thought about changing the water temp as well, but a mechanic i spoke to briefly mentioned that they normally wont read at all if at all there stuffed.
    any advice would be appreciated.
    Senior Member Casey-G's Avatar
    Casey
    What thermostat setup are you using? Fwd or rwd? Also how's the flow of moving air over your radiator?
    Thridly n probably most simple is your thermo fan working at its optimal?
    And also check your gauge and sensor to make sure your not chasing ghosts
    May 2011
    Paul
    Wollongong
    All rwd water setup.
    I assume the flow would be normal? Just using a stock clutch fan, radiator sits in a stock position. Only thing that sits in front its the old air con condensor thingo.
    Had issues with a gauge previous, but that was due to a faulty tacho. How should i be checking out the gauge etc..
    I should mention aswell, Coolant levels dont drop, and its stayed the same green colour this whole time (no discolouration etc.)
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    does it go fully into the red on the guage?????, either find someone with a thermo gun(tells temps when you point it at shit, or someone with a good multimetre that has a thermal probe
    Veteran Rice86's Avatar
    Richard
    Liverpool
    if its head gasket and in water the engine oil should go white like milk..and it should happen/overheat as soon as the car is turned on as it'll just keep eating the fluid from radiator until none left..
    if oil is still normal oil colour and fluid is not being drained from radiator, then it probably isn't head gasket if the car is still drivable like normal.
    i say flush the water system, re-fill and then bleed the water system correctly so there is little to no air in the system.
    make sure thermo fan is working and you have enough thermo fan to suit..usually 2x10'inch thermo fans to be on the safe side.
    What temperature are we talking about here because you mention it slowly goes up and drops back down..doesn't necessarily mean its overheating.
    during winter my car did not go past 70degree, now its getting warmer my car has seen 85degree highest so far, like yours it drops between 70d-85d while driving in traffic.. and i am expecting it to hit 90degree+ in summer
    EDIT
    these readings are coming from my water temp gauge i installed..and it helps a million
    dose
    May 2011
    Paul
    Wollongong
    Quote Originally Posted by lolwat View Post
    yeah generally it'll steadily climb to the last line. anything beyond that and in normally turn it off.
    Quote Originally Posted by Rice86 View Post
    well yeah everythings as per normal, no milky oil and no milky coolant.
    well yeah, ive flushed out the system a few times with water. Do you recommend getting that engine flush and running that through it?
    Im not actually running any thermo fans, just the stock clutch fan off the water pump. Someones mentioned that possibly the fan is sitting too far away from the radiator? I can get a photo if that helps?
    And I dont really have a temp reading, its just the lil old gauge in the tacho. SOunds like my best bets to grab an aftermarket temp gauge and go from there.
    Veteran timbo's Avatar
    Tim?
    Wild West
    Does then fan have any sort of shroud? Not sure if that would make a difference regarding the extremity you have mentioned.
    May 2011
    Paul
    Wollongong
    no shroud unfortunately
    Michael
    Crimebrook 2749
    thick alloy or open space
    if you where air getting drawn through a fan where would you prefer to go???
    like people who dont run front bars at track days so there front mount "gets more air" , it does more air around it, not through it
    Michael
    Crimebrook 2749
    in saying that it does it when your driving so i doubt thats the main issue, when you bled the system you have the heater on??, also if it was a head like stated above also, when you have it running with the cap off it would normally bubble away,
    if your thinking it your rad and you want ot flush it, take top and bottom hoses off, get a gardening hose going flat chat, ram it in the bottom hose barb and try and seal it with your hands the best you can, so it bhack flushes any shit back out the top (where rad cap goes and top hose barb)
  1. 4age overheating
    By Sprinter Freak in forum Technical - Questions
    Last Post: 1st October 2012, 09:58 PM
  2. Smallport AE71 Overheating issues/cluster issue, well I think so
    By pauliee in forum Technical - Questions
    Last Post: 13th August 2012, 10:26 PM
  3. Replies: 3
    Last Post: 25th February 2011, 10:03 PM
  4. Which headgasket for smallport 4AGTE?
    By maxhag in forum Technical - Questions
    Last Post: 14th November 2010, 12:23 AM
  5. 4AGE overheating problem
    By shinny in forum Technical - Questions
    Last Post: 25th November 2007, 12:31 AM
