Results 1 to 7 of 7
Thread: 20V ae86 running horrible problems
    Veteran drift kid's Avatar
    Glossodia
    Unhappy 20V ae86 running horrible problems
    Car -ae86
    motor / part in question - 20v 4age and running gear
    problem - the situation is that i have recently installed a silvertop 20v into my ae86, its running trumpets, an adaptronic ecu and individual COP's, the car has not been fully tunned but the tuners have fiddled with it a little to get it running decent for now, it has been running pretty nicely and ive had no troubles since they did this a month or so ago, but then almost two weeks ago i was driving the car and it started missfiring slightly, more under load (accel & hills) i thought it may have been fuel surges as the tank wasnt very full, then later that day on my way home she died and would not re-start and we towed her home, i thought it was just out of petrol, but once i had re-filled the tank the car still would not run properly, spluttering at first only whilst being driven and under load again, but slowly getting worse, i have checked the plugs, they are fine, ive put a few different sets in (one brand new) and none of these have cured the problem, the car now finds it hard to start and will barely idle on its own, it seems to be running quite rich (probably due to the lack of a proper tune) as there is lots of black smoke from the exhaust, it will rev but as you do this it will splutter and lose power randomly, i have checked all the fuel pump and filter at the tank and they both seem to be working fine which again is backed up by the fact that it is running rich.
    occurs/started when (if applicable)- almsot two weeks ago.
    Check your injector seals at the bottom, they crack and fall apart.. As they are side fed if they leak they'll fill your cyclinders with fuel...
    If it is running rich you'd expect your plugs to be black as well. The problem could be anything, running an engine not tuned is potentially fatal.
    Glossodia
    ill check my injectors thanx maybe stuck open? and its not un-tuned as such, it has a base tune which was fiddled with to get it half decent just for driving here and there, so that should not be an issue, also yes the plugs are black instantly
    Glossodia
    anybody?
    Moderator Sam-Q's Avatar
    Endeavour Hills
    are your coil packs genuine?
    Glossodia
    yeah genuine Toyota 1nz coils lightly filed to fit the tubes, i tested the plugs again today and found that one of them was dead, so after a new set went in it ran good but after a little drive it started to do slowly become the same as how it started before, i think it may just be fouling the plugs super quick..
    West
    Send me your tune and Ill have a look for any alarming things. Adaptronic 20v base tunes tend to come from one source and its not a good source.
  1. 20v B/T ecu problems
    By tommypots in forum Technical - Questions
    Last Post: 12th July 2011, 07:11 AM
  2. Replies: 5
    Last Post: 22nd March 2011, 07:07 PM
  3. ae86 rolling shell, silvertop 20v rwd setup running and tuned
    By mulligan in forum Car Parts For Sale
    Last Post: 21st November 2010, 09:20 PM
  4. running into problems with 20v installation
    By sprinters_r_mad in forum Technical - Questions
    Last Post: 11th December 2007, 10:26 PM
  5. 4age running problems
    By tom__86 in forum Technical - Questions
    Last Post: 20th August 2006, 06:32 PM
