Results 1 to 10 of 17
Thread: 4age rally engine builder?
    Member chacheen's Avatar
    Sep 2009
    charlie
    nsw
    narrawallee
    Default 4age rally engine builder?
    Hey guys I'm looking to get a high hp 4age built for a gravel rally car. I'm in Sydney but am happy to give the build to a garage interstate. Who's the best guy for the job.
    Whats the realistic hp I should hope for.
    Ps it has to be a 4age to comply with prc rally regs .
    Veteran Rice86's Avatar
    Richard
    Liverpool
    what is a rally spec engine?
    if your chasing power out of a 4age then it would be the same as any other build right?
    higher comp
    cams
    ECU+tune
    ITBs closed in a box since its rally..wouldn't be smart to run open quads lol..
    possible to just use a black top 20v 4age? they have been rated at 90kw at the wheels with a retune from a stock engine..
    16v 4age is possible to do the same but you spend more money
    there are a few shops that know their 4ages in Sydney so you wont need to sent it away
    dose
    Sep 2009
    charlie
    nsw
    narrawallee
    What I meant by rally engine is big hp but reliable . I'm chasing alot more than 90kw too. What's most hp you can get outa these engines
    Veteran timbo's Avatar
    Tim?
    Wild West
    200hp+ If you want a N2 spec motor. Not cheap either. Fingdthe TRD bible, it has so comparisons of race and rally built motors.
    Steve
    Hit up John aka sprinterman86 he is in penrith.
    Tell him what you want and he will tell you what you need to know.
    I know many folks who have been to him and although not the cheapest, he is one of the most honest and professional chaps i have ever dealt with and his work is second to none.
    Sep 2009
    charlie
    nsw
    narrawallee
    Any leads on his business name
    Richard
    Liverpool
    wouldn't rally and race be built on the same theory? max performance and reliability for X amount of cash available.
    yeah 200hp+ is easy with $10 000 for just the build..as mentioned would be N2 spec race engine and just sitting under a Formula Atlantic 4age engine spec i believe..and then maintenance which is part of reliability involves in tearing down the engine after each race or event to check for internal damage and then rebuild it for use again.. because you wouldn't just drive this engine for 200 000km like a standard engine would you?
    that's if your looking for anything close to 200hp+
    dose
    Richard
    Liverpool
    Quote Originally Posted by chacheen View Post
    JnJ performance...his business is advertised on this forum
    dose
    Sep 2009
    charlie
    nsw
    narrawallee
    Thanks guys .
    Steve
    Dam Richard do you hover the forums all day lol!
    Id assume for rally you would want wide torque band more then outright hp?
    Keep the oil cool and fresh same with water and johns engines will last a long time.
  1. Replies: 3
    Last Post: 12th January 2012, 03:35 PM
  2. Engine builder/tuner [BNE/SC]
    By danielgreen in forum Brisbane & QLD Events and Discussion
    Last Post: 1st January 2012, 02:36 PM
  3. Replies: 2
    Last Post: 7th October 2011, 11:28 PM
  4. Engine Builder in Melbourne
    By hitoriko in forum Melbourne & Vic Events and Discussion
    Last Post: 31st August 2009, 06:01 PM
  5. Lookin for an Engine Builder
    By james86 in forum General Topics (No Technical Questions)
    Last Post: 22nd June 2005, 05:45 PM
