Results 1 to 9 of 9
Thread: 4age 20v ST vehicle speed sensor reference for Standard ECU
    Sep 2012
    Tristan
    Koongal
    Default 4age 20v ST vehicle speed sensor reference for Standard ECU
    Car- ae86 sprinter
    motor - 4age 20v ST from ae101
    Hey all i am running a standard ECU for my ST
    i am trying to hook up a vehicle speed sensor so i don't have the 7200 rpm limit / fail safe mode on all the time
    i will be purchasing vehicle speed sensor piggy back adaptor for my T50 trans to give the ecu what it wants, how ever i need to find out what pulse per revolution does the standard vehicle speed sensor put out from the ae101?
    i have tried connecting reed switch from my cluster to ecu but with no luck,
    i have read 3 different pulses that it could be from sources off the net.
    2 pulse/ per rev
    4 pulse / per rev
    and 10 pulse/ per rev
    if anyone could confirm which it is , that would be fantastic!
    i am dieing to drive my 86
    Normally grabbing the reed off the back of the cluster works fine.
    Sep 2012
    Tristan
    Koongal
    Quote Originally Posted by Matt View Post
    Thanks matt
    have tried this again, still no go.
    i'm not saying your wrong possibly my ecu may have a fault?
    but the signal from the reed switch is a on/off earthing switch, where as the original one is 3 wire with roughly 10v coming out of it? with a positive dc wave
    i don't see how it can work...
    Member the witzl's Avatar
    Jul 2012
    Karl
    Hills District
    im sure people have used the cluster SPD output from the AE86 before....
    Otherwise a basic pull down transistor circuit using the reed switch would work. Im sure some google will answer this one.
    EDIT - googles says it should work with SPD on the ecu connected straight to the cluster's output.
    http://forums.club4ag.com/zerothread?id=43377
    KE70 Turbo 18R-G - Project Skid Car
    Sep 2012
    Tristan
    Koongal
    So this morning i've finally had time to try this scenario out again, cluster output to ecu...this time i even ran an additional earth wire from the cluster above where reed switch output is
    Still no better, however this morning it wouldn't even go past 6200 rpm....i unhooked the wire completely then it wouldn't go past 5800rpm..didn't even sound like a 20v!
    but i think i may have found the problem took the ecu apart and pretty sure i found a leaky capacitor
    anyone else think this will be the problem?
    Jul 2012
    Karl
    Hills District
    Leaky capacitors certainly will feck it up.
    I wrote a guide to fix them on the toymods.
    Check it out there.
    Also looks like you have some damage to the tracks, so might want to check it out thoroughly
    Sep 2012
    Tristan
    Koongal
    Cheers man, will have to look into it alright.. took a 2nd look this afternoon at the ecu. Looks like the cap hasn't leaked but that section has burn't out
    There is a guy in qld that'll replace the caps for you fairly cheaply in runcorn.
    Ill pm you his details if you are keen
    Sep 2012
    Tristan
    Koongal
    Thanks matt, much appreciated
    i will be taking the ecu with me to work tomorrow to see if any other techs can help me diagnose, its really odd but it looks burn't out not caps.
    i've driven the car maybe 3-4 times since i've owned it and as time goes on i guess it does more and more weird stuff!?
  1. 4age 20v ST- Microtech ecu - wiring / plug pin outs
    By Twisty92 in forum Technical - Questions
    Last Post: 23rd October 2015, 08:16 AM
  2. JDM 4AGE ECU, MAP Sensor, 20v Ignitor, 4A Brackets,
    By Killswitch in forum Car Parts For Sale
    Last Post: 18th October 2011, 12:59 AM
  3. WTB: 4age 20V st ECU
    By Dori_Dori in forum Cars or Parts Wanted
    Last Post: 7th September 2009, 11:08 PM
  4. 20v ST 4age ecu and loom and afm
    By skiddz in forum Car Parts For Sale
    Last Post: 27th January 2009, 10:06 PM
  5. 20v ST ECU
    By Kapour in forum Technical - Questions
    Last Post: 28th November 2007, 11:22 PM
