Page 2 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
Results 11 to 20 of 119
Thread: Track\Daily challenge
  1. #11
    Senior Member Noddy's Avatar
    Apr 2011
    Stuart
    Qld
    Warwick
    As it sits.. owes me about $13k.
  • #12
    Seamus
    Milton
    ohhh awesome! you came and saw me one night at a QR drift night?
    either way, car looks great, goes really well too from the looks of the things hope to see it soon
    ^ Clicky clicky!
  • #13
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    nothing like casually finding an awesome car on the way to the airport.
    quit hatin get bakin!
  • #14
    Apr 2011
    Stuart
    Qld
    Warwick
    just picked all the bits up from the machine shop, it was in a pretty sorry state. This is the list of bits going back into the rebuild/freshen up and machine work done;
    Rod and main bearings
    4 Hypatec pistions
    chrome rings
    Cometic head gasket
    ARP flywheel & rod bolts
    ARP mains and head stud kits
    resize rods
    carck test rods and crank
    match grind mains and big ends
    radius oil holes
    Tear drop oil holes
    Hone block
    ballancing machine pistion crown
    Thats all for this bill, clutch and underdriven pulley sets are on the way. I hope to see then in the next few days.
  • #15
    Apr 2011
    Stuart
    Qld
    Warwick
    Just thought I'd put some of the build tollerances ect that we have used building this engine. I have a few photos but not many, I'll try and get them up tonight but untill then... tech fodder.
    Bore 83mm (bore 3.2685, pistion 3.2665)
    stroke 77mm
    swept cap 1665.6cc
    1mm crushed commetic head gasket @ 60 ft/lbs
    combined combustion chamber 39.4cc
    Compression 10.56:1
    bore/ cylinder clearances .0002
    main bearing clearances .0015 @ 46 ft/lbs (journal size 1.8797)
    big end clearances .0015 @ 36 ft/lbs (journal size 1.6441)
    small ends .0011 (journal size .787)
    both cams measure the same, Hks, 272 deg, .338 total lift 8.5mm.
    lash on intake .0007 exhaust .0010
    both the peak openings are set about the 110 deg mark at the moment. These will get fiddled with on the dyno later.
  • #16
    Seamus
    Milton
    Very good! I am pleased to see thoroughness
    Just FYI (although i can't speak for the HKS cams because i don't have their cam cards) most of the well-known-branded 272 cams suggest approximately ~105 degree centrelines for both intake and exhaust But i guess you'll find this out soon on the dyno.
    ^ Clicky clicky!
  • #17
    Apr 2011
    Stuart
    Qld
    Warwick
    Im sure we will head in that direction with the c-line setup. The guy who is helping with this thing had full TRD support as a privateer in the NZ rall champs in the mid 80's with his 86. We were having a look at his old enging build sheets over the last few weeks and decided to start at 110 inlet and 108 exhaust. He had some crazy 4A's with cams around 320 duration and 12mm lift, 225bhp... no wonder he won the NZ grp A rally champs twice.
  • #18
    Apr 2011
    Stuart
    Qld
    Warwick
    5kg flywheel
    boxes
    numbered mains
    main studs
    ARP, the only way to roll
    Note tear drop oil ducts on the mains
  • #19
    Jake
    Northgate
    I heard that ARP flywheel bolts bottom out on 4age? Can't confirm for just another thing seen on the interwebz, haha.
  • #20
    Apr 2011
    Stuart
    Qld
    Warwick
    ARP dont list a kit for a 4age flywheel bolts anymore, could be the reason why. I will double check them to see before it gets fitted back in the car tonight.
  • Page 2 of 12 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 ... LastLast
