Results 1 to 10 of 44
Thread: 4age Conversion.
    Jan 2012
    Emmanueal
    Nsw
    Liverpool
    Default 4age Conversion.
    Hey guys, i got a few questions to ask and dont tell me to search because i have and it just doesnt make much sense :/?
    I own an AE71 and id just like to know:
    First of all, whats the difference between bigport and smallport?
    Should i get a 20v or 16v?
    How much would be a good price to pay for everything?
    Parts that i need with an AE71
    Thanks heaps in advance<3
    Veteran shift_rook's Avatar
    SE Burbs
    There's so much covering this already. First of all what is your budget? A price for 'everything' can be hard as it's hard to find it all for sale unless it's a wrecked car, will you be taking it on yourself?
    Jan 2012
    Emmanueal
    Nsw
    Liverpool
    i dont think ill be doing it myself tbh, i dont have the knowledge :/ but there isnt much of a budget, if i was to but a written off car with a 4age in it, what else would i need? just the rwd inlet?
    SE Burbs
    To pay a mechanic to put in in for you and do all the wiring i'd be budgeting 3-4k including parts, can be half if you do it yourself. Smallport NEEDS cut and shut intake manifold due to never coming in RWD configuration. Is the AE71 Manual or AUto? May be worth messaging me.
    Member the witzl's Avatar
    Jul 2012
    Karl
    Hills District
    16V Bigport has big ports, and is older. And slower.
    16V Smallport has smaller ports, and is more modern.
    When doing either 16V engine conversion, it will cost you around $2000-3000, depending on how much you can do yourself, and how thrifty you are in buying parts.
    20V is much more expensive to convert into a RWD configuration. You will usually need to go for aftermarket ECU, have to get special water outlet adaptor plates, convert the distributor to a CAS, and a few other stuff arounds.
    This is more of a $4000 conversion, maybe more.
    Of course, if you know exactly what you are doing it can be done cheaper - but i dont imagine you fit into this category.
    EDIT: getting someone else to do it will cost a lot more, unless you find someone who is willing to donate their time to do a backyard job at a discount rate.
    I've done it a few times before, and charged around $1000 labour on top of parts costs for the privledge.
    PM me for more info.
    KE70 Turbo 18R-G - Project Skid Car
    Difference between the engines
    Bigport - ~86kw
    Smallport - ~100kw
    20v - ~120ishkw)
    How serious are you about doing this? 4-5k on this conversion isn't unusual to spend if you pay someone to do the lot.
    Veteran AJPS's Avatar
    Lonsdale
    small ports are the pick of the bunch taking everything into account
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    If you don't have a budget and you can't do anything yourself, I think that kinda puts engine conversions out of the picture. Far cheaper option to buy an already converted car as long as it's been done well. Also, JDM AE86 bigports are actually rated at 98kw FYI.
    Jul 2012
    Karl
    Hills District
    for area under curve (ie, full range of power output, not just peak power), the smallport is the best of the 16v motors.
    its also my no.1 choice for bang for buck n/a 4ag conversions, especially in the lighter KE70/AE71.
    Veteran timbo's Avatar
    Tim?
    Wild West
    Agreed. My smallport keeps up with silvertops, quicker than a bigport on 272's and those late model Corolla Sportivo's! I'm not ragging on anyone here either! Fully rebuilt and all it has is bigport cams, TRD 0.8mm HG with a slightly shaved head, TRD copy headers and 2.25" mandrel bent exhaust and a decent cold air/filter set up.
  1. Replies: 3
    Last Post: 12th January 2012, 03:35 PM
  2. 4AGE CONVERSION
    By sleeperketo70 in forum Cars or Parts Wanted
    Last Post: 19th December 2011, 11:09 AM
  3. 4age conversion
    By ae13b in forum Technical - Questions
    Last Post: 15th January 2011, 11:59 PM
  4. 4age conversion
    By dr1ft-pig in forum General Topics (No Technical Questions)
    Last Post: 4th November 2005, 07:53 AM
  5. 4age conversion
    By drf72 in forum Technical - Questions
    Last Post: 3rd November 2005, 05:42 PM
