Results 1 to 3 of 3
Thread: Waterpump viscous/non viscous. Please help
    Walte
    Goldcoast
    Default Waterpump viscous/non viscous. Please help
    Hey guys I went to get a waterpump for my 16v smallport out of an ae93 today and the spare parts guy said there is two different versions. These being a viscous and nonviscous pump
    The car is an hour and a half away so I can't just check it out
    So I'm wondering if anyone could tell me which one the smallport has
    Thanks for any help guys and gals
    Much apprieciated
    Walter
    Veteran timbo's Avatar
    Tim?
    Wild West
    Maybe he is referring to the FWD vs. RWD pump. RWD pump has a longer snout and bigger bearing to compensate for the viscous fan, whereas the FWD pump has a shorter snout and it cannot be used with a fan as the bearing isn't designed for that type of load.
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Timbo is right, you will need the "non viscous" pump". All you need to do to make sure is see that the length is the same.
  • Similar Threads
    1. WTB Viscous Coupling in good working condition
      By extra_anchovy in forum Cars or Parts Wanted
      Last Post: 16th January 2012, 10:02 AM
    2. 4age waterpump :)
      By Drift_Donkey in forum Cars or Parts Wanted
      Last Post: 18th August 2010, 06:16 PM
    3. what waterpump do i use?
      By 86TRD in forum Technical - Questions
      Last Post: 10th February 2010, 12:49 AM
    4. Waterpump, Brand new
      By NIZLAH in forum Car Parts For Sale
      Last Post: 25th January 2009, 09:20 AM
    5. 4ac waterpump same as 4age rwd waterpump?
      By simonster in forum Technical - Questions
      Last Post: 25th October 2007, 10:11 PM
