Results 1 to 10 of 15
Thread: 4age overheating
    ryan
    Default 4age overheating
    Car - ke70
    motor - 4age
    problem - overheating
    occurs - when skidding
    hey guys
    now i know this seems like a silly question but i cant see why its getting so hot. Its a got a genuine koyo radiator which is pretty big, fresh tectaloy coolant and a 12 thermo fan so it should stay nice and cool. but after a few runs on eastern creek wet pan its getting pretty hot. only thing i could think of that it could be is maybe my fan mount blocking too much of the rad orthat the thermostat isn't working properly(am planning on taking it out). Do you guys have any ideas how i could stop it getting so hot?
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    do not take your thermastat out
    do you have aftermarket guages????
    mount the fan directly on the rad, piss all that alu sheets off,
    if you knew a fabricator, you would get them to make you a shroud that has the fan about 25mm off the rad, as there is a static deadset infront of most fans, so having it mounted 25mm or so off the rad, will allow the fan to work at its best
    Take the thermostat out and put it in a saucepan and boil it on the stove... make sure it opens up.
    What is your water pump like?
    ryan
    Quote Originally Posted by lolwat View Post
    nah man i've just got the standard guages, so knowing what temp its at is a bit of a guessing game. but you can tell when its heating up. yea i dont really want to mount it directly to the rad as it was expensive. hmm may look into getting a fan shroud made up thats spaced off the rad.
    Quote Originally Posted by Matt View Post
    yea ill grab it out sometime this week and give that a go. water pump is fresh, put a new one in when i put the motor in.
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    ^^ As he said. Get rid of that alu sheeting and mount with more "suction" (no gaps) to the Rad. A shroud would be best if you dont want to mark the radiator. (Just a note mate, drifting damages cars if you like it or not
    Just some basics, but Have you checked that the fan is actually turning on?
    What are you using to control the fan? (ie; ECU, thermostat sensor/probe adjuster, etc) What temp does it come on at?
    Do you have an oil cooler?
    2 10" fans would be better than the 12" in my opinion....
    The car is obviously producing more heat when racing, so it will be hotter. I am not sure how the stock gauge is calibrated, ie; what the actual temp is when is rises. A temp gauge would really help....
    Adan
    Oxley Park
    Just to reiterate what has been said.
    -Get a proper temp gauge
    -Make a decent fan mount
    -Check that thermostat works
    Ive done full days on the wetpan and never even had to turn on the thermo fan while driving, just for reference.
    Michael
    Crimebrook 2749
    bash limitier for 4 minutes(not moving) with alu rad iand it doesnt overheating yours should be fine man, do what everyone has said and you should sort it
    ryan
    Quote Originally Posted by maxhag View Post
    haha yea i know drifting wrecks your car, found that out last saturday. yea i know the fan is turning on, i checked when i pulled into the pits. well there isn't much controlling the fan, its just always on She guy who wired up my car didn't put a temperature switch in for the fan. He just wired it so it comes on, on start up. Nah i don't have an oil cooler, am contemplating getting one. Was looking at getting something like this http://www.ebay.com.au/itm/350601623...ht_4574wt_1182 and doing away with my current setup. I know its an ebay one but i cant find any better ones that come with fans as well.Yea i think ill have to grab a temp gauge from work and put it in.
    Quote Originally Posted by meadan View Post
    yea i can see that from reading the previous comments.
    does anyone know if jap ae86 4age thermostats are the same as ae82/92 ones? looking at getting a low temp thermostat for an ae86 but want to make sure its going to fit.
    Aug 2010
    Sutho Shire
    dont hold me to it but ide get a ae82 thermostat as they had a bigport which is whats in a jap 86,so should be same,shouldnt cost much anyway if you go repco,bursons etc,not on topic but i removed the fuel pump from my jap tank( baffled) took it to repco and part number was same as a ae82 fuel pump,so they probally share a few parts
    Adan
    Oxley Park
    im pretty sure theyre the same.
    And dont get a low temp one, just get a normal 82 degree one. No point hiding the other issues by using a lower temp thermostat.
  1. Overheating Smallport 4age AE71- Headgasket?
    By pauliee in forum Technical - Questions
    Last Post: 28th September 2012, 02:01 AM
  2. sr20det overheating issues (I KNOW ITS NOT A 4AGE)
    By Fozz in forum Technical - Questions
    Last Post: 22nd March 2009, 11:14 PM
  3. 4AGE overheating problem
    By shinny in forum Technical - Questions
    Last Post: 25th November 2007, 12:31 AM
  4. How hot does your 4age need to get and for how long till its OVERHEATING?
    By Wanabe_Garage in forum Technical - Questions
    Last Post: 24th November 2007, 12:56 PM
  5. Engine Overheating
    By fozz in forum Technical - Questions
    Last Post: 17th September 2007, 02:03 PM
