Results 1 to 10 of 18
Thread: W58/4a clutch trouble
    Junior Member Fashionbmx's Avatar
    Dec 2010
    Daniel
    Blackburn
    Default W58/4a clutch trouble
    Hi I have a w58 box with a 4a bell which I think is from new Zealand .
    Im running a ra60 slave ,standard ae71 master.
    Im using a t50 fork an everything externally lines up really well but
    It doesn't seem to throw far enough .
    Clutch works but the pick up point is right at the floor ...
    The pedal has been adjusted an made a little difference but not much ..
    I was wondering of any one on here has any info on what set up other people have used and if someone has had
    the same sort of trouble and how did they rectify it
    Thanks
    daniel
    Veteran willa's Avatar
    Will
    Northern 'burbs
    Maybe you could make a shorter/longer push rod from slave->throwout lever. It's 6mm rod iirc
    Dec 2010
    Daniel
    Blackburn
    Thanks for the reply mate I have put a longer push rod in but I wasn't sure how long it can be before it might pop out with bumps and that if you know what I mean
    Will
    Northern 'burbs
    Yeh mate, and you dont want to over-extend the carrier off the shaft (not sure if it's possible, but still a scary thought).
    I'm 95% through them same conversion, except i used a 22re slave, so ill let you know if i have the same dramas.
    Cheers,
    Will.
    Dec 2010
    Daniel
    Blackburn
    Sweet as man I hope it works out for you first go cause this has been the biggest bastard to work out hahaha ...
    keep me informed for sure
    I used the w58 fork in mine.... There are also kits which remove the fork all together out there...
    http://forum.twincam.org.au/topic/29...-w57-w58-r154/
    Senior Member 20v ae71's Avatar
    Dillon
    I thought you were supposed to use the ae71/86 slave?
    Andrew
    East Melbourne
    Quote Originally Posted by Matt View Post
    I just purchased one of these kits.. hoping it will show up this week!
    They look awesome and Bazda was good to deal with.
    Not sure what the slave is... was that long ago, but my bell is a diff brand too, so could be why the w58 fork worked.
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    I had similar issues when doing my W box conversion, had to play around with the slave push-rod length to get the pedal/engagement to feel right as there wasn't enough adjustment on the pedal. This was with a niteparts bellhousing and jdm/t18? slave cylinder.
    BENT MECHANIX - Garage 20:
  1. WTB: 4A - W58 adapter
    By Philbo in forum Cars or Parts Wanted
    Last Post: 7th November 2012, 12:37 AM
  2. w58 conversion for 4a
    By No Offence in forum Cars or Parts Wanted
    Last Post: 28th May 2011, 08:28 PM
  3. w58 conversion 4a Sydney
    By spoon in forum Car Parts For Sale
    Last Post: 29th May 2009, 02:41 PM
  4. 4a - w58 clutch 200mm flywheel
    By redsprinter in forum Technical - Questions
    Last Post: 27th September 2008, 05:26 AM
  5. ae86 4a to w58 xmembers
    By reecegze in forum Cars or Parts Wanted
    Last Post: 25th June 2008, 11:06 PM
