Results 1 to 9 of 9
Thread: smoke and idle problems?
    Junior Member nburr20's Avatar
    May 2011
    Nathan
    Default smoke and idle problems?
    so went to the track today for jap nats took the car out at lunch for a spectator cruise, did about 3 laps of pushing to about 6,500-7,500 and smoke appeared under my bonnet came straight off and popped my bonnet i have smoke coming from my oil catch can and when not on accelerator it keeps wanting to stall, drove home, not reving over 3,000 seemed to run fine just had smoke coming out from behind me
    anyone have any ideas what this could be
    thanks nathan
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    do a comp test, excessive blow by
    Senior Member dansomerville's Avatar
    Jun 2011
    Daniel
    Townsville
    I was thinking about this on my way home after talking to you, blue or white smoke? Maybe rings or HG, seems odd.
    May 2011
    Nathan
    Quote Originally Posted by dansomerville View Post
    id say its more white smoke, i have fixed the idle problem or it fixed itself but still has smoke coming from the catch can
    Michael
    Crimebrook 2749
    have you checked your oil at all?
    May 2011
    Nathan
    Quote Originally Posted by lolwat View Post
    yeah oil is 3/4 full, only topped up the other day
    Michael
    Crimebrook 2749
    hmmmmmm, when i cooked my 4a(it stopped) i had white smoke pissing out of catch can, but next day(when returned to it on the side of the road) oil level was fine, white is normally coolant or brake fluid(wouldn't be this one)
    Jun 2011
    Daniel
    Townsville
    Get a hold of a comp tester and test each cylinder. Maybe drop your oil and check for any sign of water in there.
    Veteran timbo's Avatar
    Tim?
    Wild West
    It's probably your valve stem seals. I think I've got a dud one in my car as there is a little smoke taking off from lights etc. It happens so little I haven't got around to fixing it but its on the to-do list.
  1. 16v bigport IDLE problems
    By TOFU in forum Technical - Questions
    Last Post: 15th February 2011, 08:16 PM
  2. idle problems and wont coast under 3000rpm on 4age in ke70
    By imprezd in forum Technical - Questions
    Last Post: 5th June 2010, 01:37 AM
  3. 4ac Craby problems.. Choke+Idle
    By tc-rolla in forum Technical - Questions
    Last Post: 7th August 2009, 11:29 AM
  4. 4ac idle problems
    By Jarrod in forum Technical - Questions
    Last Post: 21st March 2008, 12:29 AM
  5. White Smoke
    By Pat_AE86 in forum Technical - Questions
    Last Post: 17th February 2007, 07:15 AM
