Results 1 to 8 of 8
Thread: Genuine Remanufactured Denso 80Amp Alternators & 1.4kw Starters
    Veteran Golberg's Avatar
    Lawrence
    Wollongong
    Default Genuine Remanufactured Denso 80Amp Alternators & 1.4kw Starters
    As some have already noticed I'm about to do another order of starters but I've also nailed down an 80A alternator.
    Both items are genuine Denso, remanufactured by Denso themselves.
    Description of Alternator:
    The standard 4AGE alternator is either 60 or 70Amp depending on model.
    I've just secured a supplier for a rare 80Amp unit that will bolt up and plug straight into just about any 4AGE setup. It is a remanufactured genuine Denso unit done by Denso themselves. No aftermarket rubbish just quality OEM goods.
    Description of Starter:
    I recently found a new supplier for these. They are rebuilt by Denso themselves, basically equivalent quality of brand new genuine. As an auto electrician I see a lot of failed starter motors, this particular type of Denso gear reduction starter is hands down the best and most reliable starter there is.
    This particular model is the highest output 4AGE starter there is. I don't think you could even build a 4AGE with high enough compression for it to even struggle. It packs a whopping 1.4Kw
    They will fit the following OEM applications.
    AE86 4AC & 4AGE
    AE71
    AW11 4AGE MR2
    AE82 4AGE
    AE92 4AGE
    They will also fit any 4A motor bolted to a T50, and most 4A-W5x bellhousings. Basically if your standard 4AC/4AGE starter fits from any of the vehicles listed above this will fit too.
    Lawrence
    Wollongong
    Photo added of alternator. The only real exterior difference is slightly different locations of the + Post and the regulator plug. I haven't had any issues with wiring not reaching in anything I've had to fit.
    Just as a heads up also, it comes with a round plug regulator. If you have a 20V you may have an oval shaped plug on the back. If so let me know because I think there is an oval plug 80A unit available also.
    One other interesting note, it has a larger front pulley than a standard 4AGE type one = slightly underdriven to help cope with higher operating RPM's
    Lawrence
    Wollongong
    Last chance guys, need money by the end of this week.
  • #4
    Veteran McLEVIN's Avatar
    Nov 2010
    Will send money Fri.
  • #5
    Meh I'll take one also..won't hurt having a spare..
  • #6
    Anyone heard from Golberg?? wanting confirmation I can still get in on the group buy before transferring cash..
  • #7
    Lawrence
    Wollongong
    I'm here, just didn't have a chance to get on in the past couple of days. Replying to the long list of PM's now.
  • #8
    Lawrence
    Wollongong
    This group buy has past now.
    New thread here, for anybody wanting either of these:
    http://www.ae86drivingclub.com.au/fo...s-amp-Starters
  • Similar Threads
    1. Wanted: Dead 4AGE alternators & starters, Dead T50's
      By Golberg in forum Cars or Parts Wanted
      Last Post: 7th January 2011, 08:49 AM
