Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 32
Thread: how tight do fly wheel bolts have to be !!!'??
    Jul 2012
    jedd
    nsw
    ocean shores
    Default how tight do fly wheel bolts have to be !!!'??
    hay what do i set my torque wrench at to tighten my flywheel on my 20v 4AGE silvertop
    ANYONE KNOW??
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    fucking tight, with loctite
    Gunner
    Exactly what I was going to say. Hahaha..
    Jul 2012
    jedd
    nsw
    ocean shores
    haha yeah i know that but i need to know the numbers thanks anyways
    Michael
    Crimebrook 2749
    whats the highest on your torque wrench?
    Veteran Rice86's Avatar
    Richard
    Liverpool
    Quote Originally Posted by lolwat View Post
    HAHAHAHHAHAHAHAHAHAH
    yeah dude as tight as the bolt will allow before you snap something, but good luck snapping something before you pull a muscle..anyways after all these clutch and flywheel changes on stock motors that sees 7500 very often, super hand tight has worked enough so tight as tight and you'll be alright.
    dose
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    I have never looked it up for a 4age, but cars at work (VW) are 90nm+90 degrees with loctite from memory.
    That's what I did to mine 2 years ago and it hasn't come off, touch wood, but I didn't use loctite as I didn't have any.
    bursting ovaries since 92'
    Veteran Skylar's Avatar
    Ken
    totally irrelevant but CA18 is 98-108Nm/72-80lb.ft
    Also, overtightening is better than undertightening.
    Mar 2012
    Brett
    Vic
    Morwell
    The flywheel bolt torque for a 4age 20v bt is 75nm's.
    I presume the tension would be the same for bt and st
    And thats straight out of the toyota workshop manual
    Elite rthy's Avatar
    Leo
    Tulla
    don't over do it, they are only 14mm bolts
    Last edited by rthy; 26th September 2012 at 10:40 PM. Reason: edited to correct bolt size as pre next page :>
  1. Replies: 9
    Last Post: 5th June 2013, 11:32 AM
  2. 4age fly wheel wanted
    By Alfie.. in forum Cars or Parts Wanted
    Last Post: 31st August 2010, 07:43 AM
  3. Fly Wheel Bolts
    By Monk in forum Technical - Questions
    Last Post: 24th November 2006, 10:18 PM
  4. 4agze Fly wheel into a 20v
    Last Post: 26th March 2006, 09:58 PM
