Results 1 to 5 of 5
Thread: What shock's to use in home made coilovers?
    Senior Member Zane k's Avatar
    Aug 2011
    Zane
    Gold Coast
    Default What shock's to use in home made coilovers?
    Im using xt130 struts with the hsd coilover sleeves and I was wondering what shocks would be best to use in them and also how much you should cut out of the tube.
    ​Thanks.
    TailorMade☆DC
    20v 4AG Corolla:
    Aug 2010
    Geoff
    mt dandenong
    there are a few guides around, do some good searching and you'll find them.
    what inserts really depends on your budget, most people settle with kyb's but you can get bilsteins if you want to spend more.
    know what spring rates your going to run? what do you use the car for mainly?
    Veteran Skylar's Avatar
    Ken
    8611-1259 koni pr 8610-1437 if you're happy with single adjustable shocks
    or some valved bilsteins.
    Mark
    I used koni yellows out of an ae92, took 40mm out of the strut and put a 20mm spacer in the bottom, this is all from memory though
    West
    Im running sw20 mr2 koni yellow in one car and st185 koni yellow in the other.
    The st185 is for those who like their cars low. My coilovers are just cut to suit 332mm shock body of sv21, st185, or ae92 shocks. I think its just a bit too short a setup. Im using the sw20s to get more stroke and adjustment.
  1. MR2 AW11 - 20v Blacktop, coilovers, to good home.
    By alexthem0nk in forum Cars for Sale (Toyota Only)
    Last Post: 2nd December 2010, 05:12 PM
  2. HOME MADE FIBERGLASS
    By orangechargd86 in forum Technical - Articles
    Last Post: 16th May 2008, 09:55 PM
  3. AE86 jap made coilovers
    By slippry in forum Car Parts For Sale
    Last Post: 4th January 2008, 02:36 AM
  4. Home made fibreglass replacement panels
    By majic86 in forum Technical - Questions
    Last Post: 24th December 2005, 09:30 AM
