Results 1 to 5 of 5
Thread: Extra lock question?
    Member Alexrex7's Avatar
    Jul 2010
    Alex
    Qld
    Goldy
    Aussie
    Default Extra lock question?
    Just ordered some T3 arms and tie rod ends for my 86 front strut conversion into a KE70. Just wondering if i will need inner rack spacers or anything else to make it all work and get more lock without binding scrubbing issues etc? Thanks
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    recommend lock spacer, as ke70's lack lock, due to rack
    Jul 2010
    Alex
    Qld
    Goldy
    Aussie
    The knuckles come with longer adjustable tie rod ends will that be enough to make the rack travel further or will I definately need a lock spacer as well? And anyone know if I will have to run xt130 LCA?
    Jul 2010
    Alex
    Qld
    Goldy
    Aussie
    So just wondering if the extra length tie rod ends will make up that extra bit of space that the KE 70 rack lacks?
    Senior Member Jip86's Avatar
    Lindsay
    Mackay
    Quote Originally Posted by Alexrex7 View Post
    No, the longer tie rods just allow you to run xt130 arms without the danger of the rack end and tie rod coming apart because there isn't enough thread engagement.
    I'd throw the t3 gear in and get either a lock spacer or machined rack ends and leave the xt130 lcas off for now as it will make scrubbing worse everywhere.
  1. extra lock rack ends
    By VTAZ! in forum Technical - Questions
    Last Post: 5th October 2010, 04:34 AM
  2. Extra lock spacer
    By loc33e in forum Technical - Questions
    Last Post: 22nd January 2008, 05:45 PM
