Results 1 to 1 of 1
Thread: ASD - 90 Deg Straight (Blue & Black)
    Junior Member Aus Silicon Direct's Avatar
    Jan 2011
    Sales
    Default ASD - 90 Deg Straight (Blue & Black)
    All of our Silicon is handmade as is constructed from one of the toughest and most common polymers available to date. They are also reinforced with polyester which gives many advantages which is great with high temperatures and pressures. Our great range of Silicon Joiners is extremely strong and durable. With these key features they are great for Automotive uses.
    Aus Silicon Direct has many sizes available from 1" ID all the way through to 5" ID depending on which style of Silicon it be, whether it be Straight Joiners, Straight Reducer, 45 Degrees Elbow, 45 Degrees Reducer, 90 Degrees Elbow, 90 Degrees Reducer. If you can't find it on our website, please don't hesitate to contact our friend Sales Team for a pricing on the item that you need.
    Silicon 2 Inch ID (51mm) 90 Deg Straight - Our Price: $22.00
    - Working Pressure -43 to 145psi
    - Working Temperature -60 to 220c
    - Burst Pressure 300psi
    - Thickness 4 - 5mm think / 3 - 4mm ply
    - Colour: Blue / Black
    Silicon 2.25 Inch ID (57mm) 90Deg Straight - Our Price: $25.00
    Silicon 2.5 Inch ID (63mm) 90 Deg Straight - Our Price: $29.00
    Silicon 2.75 Inch ID (69mm) 90 Deg Straight - Our Price:$33.00
    Silicon 3 Inch ID (75mm) 90 Deg Straight - Our Price: $36.00
    SO, HOW DO I ORDER???
    It is easy:
    1. Firstly find out which Silicon Joiner/Joiners you wish to order
    2. Send our friendly sales team a Personal Message, or contact us via email Aus Silicon Direct Sales
    3. Then we will get back to you with a Payment Method to suit your needs, and your parts will be delivered to your door - no hassles!
    Any questions, please don't hesitate to contact us with the methods above!
