Results 1 to 10 of 11
Thread: Catch can routing
    Senior Member dansomerville's Avatar
    Jun 2011
    Daniel
    Townsville
    Default Catch can routing
    Probably a stupid question, just after some thoughts.
    When installing a catch can, should I run a hose from the PCV and the cam cover breather to the catch can or just the cam cover and leave the PCV as it is into the throttle body? And theoretically I could run the outlet of the ISCV that's meant to run back to the standard intake surge tank to the catch can as well, correct?
    Veteran timbo's Avatar
    Tim?
    Wild West
    Not sure on 20v's but on mine, 16v, it goes from cam cover to catch then catch can to PCV (in theroy...). The PCV is a oneway valve running only vacuum which sucks the crank case ventaltion into the intake manifold to meet emissions, as apposed to venting atmospherically via a draft tube, which is not so legal...
    Jun 2011
    Daniel
    Townsville
    Yeah my 16v one is completely illegal, runs from cam cover to catch can, and then catch can runs a hose(assuming this is the hose that's meant to go back to intake manifold, or to a filter) the length of the car and finishes at the bumper, haha. And has a drain back to the sump at the bottom.
    So the PCV requires vacuum pressure to operate it and shouldn't be routed to the catch can as a dump? I was just thinking under the theory you didn't want any seedy air going back into the throttle body if it was possible therefore only routing the cam breather to the catch can was only doing half the job.
    Tim?
    Wild West
    Well, once upon a time there was no crankcase ventilation and this would cause moto's to seep oil through gaskets etc due to the blow by. What you had on your 16v is ideal, it is not legal however! PCV is an emissions control device so you should run it in a system, even with the catch can it can still work.
    From motor -> catch can -> from catch can -> intake manifold
    The catch can will "catch" oil and blow by, from there the intake vacuum pulls any gas left over, in the catch can, to be burnt through the combustion chamber.
    Jun 2011
    Daniel
    Townsville
    Yeah wicked, I just wasn't sure if vacuum was required to activate the PCV valve. Will just set it up as before using a filter or back to the manifold. I don't like the idea of maybe dropping any oil on the road for people following me, haha. Just have to tap a return into my sump now then.
    Cheers.
    Tim?
    Wild West
    Yep, return line is the go, should do it on my car but I've only got a shitty little cusco catch can!
    Jun 2011
    Daniel
    Townsville
    How quickly does yours fill?
    West
    Leave the pcv connection and valve intact.
    Run a hose from top cover breather to your can and if your motor pops the dipstick up a bit to let gasses out at high rpm then you can put a hose on the dipstick tube also.
    No need to drain back, the oil that comes out is feral and contains water vapours.
    Tim?
    Wild West
    Whatever Matt says regards to 20v's. I don't run it back to the manifold because it's creamy and clogs shit up.
    West
    Quote Originally Posted by timbo View Post
    Id have one off the dipstick and one off the top cover breather on any engine. Not specifically 4ages, but any engine you will drive hard. Cams and road laws state only that the dipstick must be installed in the car, they do not mention where.
  1. BT 20 valve wiring loom routing options AE86
    By _sawyer_ in forum Technical - Questions
    Last Post: 26th June 2012, 07:05 PM
  2. Replies: 0
    Last Post: 18th September 2011, 02:40 PM
  3. Catch can setups.
    By fantapants in forum Technical - Questions
    Last Post: 10th August 2009, 07:11 PM
  4. catch can
    By drftr86 in forum Technical - Questions
    Last Post: 20th August 2007, 08:13 PM
  5. power mirror wire routing
    By parrot in forum Technical - Questions
    Last Post: 22nd July 2007, 10:53 PM
