Hey guys
Putting my cefiro up for sale, basically, finished building it, engineered for all mods under the new VCSS rules for NSW.
Was planning to drift it, but not sure if I can bring myself to potentially damage it.
1990 Cefiro.
RB20DET out of a r32 with around 120k. Even comp, zero blow by
Timing belt, water pump, rocker cover seals, exhaust manifold studs and gasket all done while motor was out.
Return flow cooler
r33 turbo
Split dump, 3 inch exhaust, Catco cat, cannon.
Cam gears
Stock r32 airbox
Bleed valve
r32 ecu and loom, wired into cef body loom so everthing works. Loom also has consult port added (was planning to do a nistune) that cefiro's didnt have.
R33 turbo gearbox, excedy single plate organic clutch.
two piece talshaft modified to suit r33 box.
Cusco 2 way, 4.3 ratio
Brakes, suspention
5 stud conversion, using s14 front lca's (bit more camber)
r33 gtst brakes all round, near new pads and discs r32 master cyl
BC br coilovers
GTR rear sway bar
Pillow ball tie rods
6mm rack spacers
Hicas fully deleted, lines the lot. r33 power steering pump used.
Alloy cradle washers
Front carbon strut brace
Buddy club P1'S 17x9 +27, 235/45/17s all round
Interior, exterior
Nismo gear knob
Nardi rep wheel
S15 seats
Factory cefiro floor mats
Boost and oil pressure gauge in consol.
No air con.
All electric windows, mirrors work.
Dash lifting a little
Full uras copy kit, few cracks on front bar and side skirts, rear ok.
R32 gtst wing (for upper 3rd brake light)
Has been resrayed plain white at some stage, body is how I bought it, dont like spending money on the body
Car has been engineered under the new rules in NSW, never had a issue with the police.
Coilovers, brakes, clutch were all new, done 14000km since I got it on the road. Rego till may 2013
$12000. not very neg, not overly fussed if it sells, its a fun street car.
I know there's cheaper ones, and ones with RB25, but mines all legal, engineering cost a packet too!
May possibly be up for a trade for a track car, with cash my way. Keen to try a toyota, hence posting in here
Located south coast, NSW,
Pm only.
