Results 1 to 10 of 10
Thread: longer rack ends for ke70
    ryan
    Default longer rack ends for ke70
    hey guys
    Just wondering what other rack ends are out there that are longer then the standard ke70 examples? have been playing around with the track on my car so i don't rub my inner guard on full lock. But have run out of adjustment on the tie rod end/rack end. Have heard that ae86 power steering rack ends are longer but don't know by how much, anyone know?
    Ryan
    ryan
    also is there a way to stop the tyres rubbing the tension rods on full lock? would getting lower offset wheels should fix it?
    Aug 2010
    Sutho Shire
    what offset wheels do you run?i run a 14x8 neg 18 on front with decent lock,it only just rubs chassis rail on full lock when traveling at speed,nothing else rubs at all
    ryan
    i've got 15X7 -1 on the front. The only thing that it rubs on is the tension rod at nearly full lock everything else clears.
    Jake
    Northgate
    RA60 celica ones are a fair bit longer.
    You will need wider wheels with more - offset of spacers either of those will be the easy way. Or get more front end track.
    Veteran AJPS's Avatar
    Lonsdale
    get longer control arms?
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    RA60 rackends are longer
    ryan
    Quote Originally Posted by jakel View Post
    Quote Originally Posted by lolwat View Post
    Ok sweet that's just what I was after, will pick up a set of ra60 rack ends from work. Ah K may look into running a small slip on spacer on the front as well.
    Quote Originally Posted by AJPS View Post
    ive got t3 adjustable LCA's so I've got enough adjustment in them to make it clear, its just that the I didn't have enough rack end adjustment left to track it out anymore with out getting mad toe out.
    Senior Member sam92's Avatar
    Jul 2012
    Wagga Wagga
    I had this issue the other week and got ra60 rack ends to run with new stock ke70 tie rods and xt130 lcas. I haven't put it all together yet but apparently works out sweet
    ryan
    yea have ordered some so should be putting them in tomorrow, so ill see how i go.
  1. XT130's with P/S rack, longer rack ends?
    By Jimmee1990 in forum Technical - Questions
    Last Post: 6th December 2011, 07:31 PM
  2. [melb] rack ends and rack bushes
    By shakes in forum Car Parts For Sale
    Last Post: 10th May 2010, 09:28 PM
  3. Replies: 0
    Last Post: 5th March 2010, 06:59 PM
  4. rack/tierod ends for longer LCA's
    By --Redwork-- in forum Technical - Questions
    Last Post: 16th December 2009, 11:30 PM
  5. Replies: 1
    Last Post: 3rd November 2009, 07:52 PM
