pics will be soon
Got engine
started making frame for fuel cell
Magic man Lower control arms and caster rods
Dash has been gutted completely
going with little mike this sunday to get it
pics will be soon
Got engine
just because this peasant never updates, I made the rear equal length trailing arm boxes and we cleaned out the back of the ke plus marked it all out ready for cutting, 40*+ temps slowed the progress stupid fast lol
bam!
Good work! What is the thickness of the steel you used for the box sections? I'm planning to to the same
box sections are looking good man. needs more tubs all round tho
2mm plate, i believe
got to clean up underneath as benny smashed the other box () last night, looks fuckin awesome, just rear tunnel area to do now, need to shorten panhard rod mount on my diff as its made for watts link, add a bar so i can have 2-3 panhard bar mounts/levels(if clay comments saying half assing not going watts link, ill bite your face off), weld on spring perches, powder coat, get new crown and pinion setup and thats diff done
chiseling sound deadner out, isnt as mad as people make it out to be, do a little bit in between things its not too bad
fronts yes rears no
both rear boxes are done, rear tunnel is done, now have a diff center that has been welded to the fucking shit house, cut off watts link mount and shortened the other one, ready to weld on 10mm stainless plate so i can have panhard at different heights, spring perches have been welded on, so diff is nearly done ready for sandblast and powder coating
bought a 3m speedglass 100 series helmet, so i can get cracking on welder as there wasn't one at my factory
i think you ####s need to start working on the ej86. seriously good effort dude get more pics up you slut
Benny has pumped work, ive been a bit lazy, did a bit on the welder today, pretty happy wth my self(jumped in the deep end a bit welded spring perches on), so ill get smashing every seam with wire wheel, and seam welding it all
once diff is in(rolling again) going to flat tow/push, it around to bennys work, so he can make a lovely alum frame and jacking point in the back, then i can start fuel setup, waiting on invoice from bills auto fab as well so i can pay the mofo hahahah
hurry up #### hahahahah, ill beat you
