Results 1 to 10 of 13
Thread: Checklist for an engine conversion!
    Jan 2012
    Emmanueal
    Nsw
    Liverpool
    Default Checklist for an engine conversion!
    Hey guys, i know shit like this has been asked a million times but ive tried looking and i cant find what i need.. So im on the urge of buying a 20v and i was wondering is there a certain checklist that i can use to make sure i have all the parts for a conversion? because i dont wanna start and then halfway realise i have more hard to get parts i need to find?
    If not, when i get a motor with the wiring harness and the computer, what else will i need? other than gearbox and the waterpumps? i have an ae71 if that helps so theres no crossmembers and shit i need,
    cheers!
    Moderator Sam-Q's Avatar
    Endeavour Hills
    Jan 2012
    Emmanueal
    Nsw
    Liverpool
    ill be honest, i still dont understand this-.- i just want like a checklist, so i can buy all the parts i need and drop them off at a mechanic
    Senior Member J0RD0's Avatar
    Feb 2010
    Jordan
    I'd hate to pay someone to do a conversion for me. If you want my advice try and hang out for one that's ready to go (either car or complete engine package to come up. They do from time to time and swapping gear over from car to car is easy, even your grandma could do it
    THE EVOROLLA none of this SR shit . . . EVO 7 powered bitches
    https://www.facebook.com/KeConversions
    KE conversions - making your conversion simple
    4AGE CA18 SR20 BEAMS 1UZ to KEXX mounting kits and hydraulic pedal box's available
    Jan 2012
    Emmanueal
    Nsw
    Liverpool
    hmm, good idea, how much would a complete smallport go for? or a complete 20v?
    Jake
    Northgate
    Good chance you will have to get extra parts anyway.
    Need engine bits.
    Bigger brakes if you want.
    Better suspension.
    And then the rest, mod plates/engineering, ect. Just make sure you know it won't be cheap.
    Senior Member dansomerville's Avatar
    Jun 2011
    Daniel
    Townsville
    http://www.ae86drivingclub.com.au/fo...0v-rwd-package
    Buy, install, drive. Doesn't get much simpler.
    Jun 2011
    Daniel
    Townsville
    Doing it yourself can be fun too, the amount you learn is amazing and unless your rebuilding the engine there's not that much you can mess up either. It will also be a lot cheaper, will improve your skills, give you a good sense of accomplishment and people won't give you crap for someone else building your car.
    I don't know very much about anything but I just completed a blacktop swap from a bare short motor. People more in the know are always willing to help you out all you have to do is ask and troll the Internet.
    Good luck anyway.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    i will have soon, everything apart from pedal box, clutch master, clutch lines and the engines fucked, so loom,ecu,zorst(2 1/4" 2 lukey mufflers),intake,water setup(not including rad), X members, speedo cable,, tailshaft, gearbox
    i should be able to remove from my car and install into yours if you supply another bigport, pending getting mine into factory in the next week or so
    Work out first if you want factory ecu or aftermarket
    that will make the ecu/wiring loom optional
    Package wise
    Engine, quads, dizzy, igniter , coil, alternator, iscv , knock sensor, either map sensor or afm. If you buy from SSS they are good and will include everything to run it.
    Aftermarket bits easy to get are kaizen extractors / wiring loom / adaptronic , samq dizzy relocation / water kit. Spigot bearing do not forget this.
    what car are you putting it into?
  1. dropping ae86 fuel tank (JDM) checklist
    By b1gb3n in forum Technical - Questions
    Last Post: 28th June 2011, 03:14 PM
  2. Service Checklist?
    By haydenz in forum Technical - Questions
    Last Post: 14th January 2010, 01:46 PM
  3. Engine Conversion
    By TRD-trueno in forum Technical - Questions
    Last Post: 25th April 2007, 02:06 AM
  4. Engine conversion
    By sw1fty in forum General Topics (No Technical Questions)
    Last Post: 27th June 2006, 03:53 PM
