just came from typing "how to fit 4age to ae71" in a google search.
good luck with the conversion.....
Checklist for engine conversion:
1 - Another car to drive (to Bursons/wrecker/work) while you do the conversion
2 - More time than you think
3 - More money than you think
4 - An engine and a bunch of other associated parts
here is what I can offer for the conversion:
- RWD cooling kit with heater use
- Velocity stacks
- spigot bearing
- distributor blanking cover
- coil-pack adapter plate
- coil-packs
- Rear wheel drive clutch line
after this all you need is some slide on filters and an aftermarket ECU and loom package. The usual fuel upgrades are also necessary for the EFI conversion but otherwise that's it.
If your going to run a stock ECU then then you don't usually use coil-packs and the adapter plate but rather a distributor cap relocation kit.
