Results 1 to 10 of 14
Thread: metal HG's
    gawler area.
    Default metal HG's
    what brand of metal HG's are people using on there 16v 4ag ?
    hachi roku
    Veteran timbo's Avatar
    Tim?
    Wild West
    TRD
    Good quality and not very expensive really. Someone did tell they leak and I won't have anything but problems and recommended cometic, but well over 12mths now the TRD hasn't had a problem. I am probably a bit biased towards Toyota/TRD as I have a lot on the car already, I figured TRD would be the best as they know best! Advantages from using others like cometic is the availability of different bore sizes.
    Samq has the TRD ones...
    I've always used genuine gaskets, I also have the opinion that its better to blow a hq than destroy a head as the head gasket should only blow if something is wrong.
    Veteran Skylar's Avatar
    Ken
    Apexi. Cosworth is good too. but that's from SR20 guys. Dunno about TRD stuff.
    Cometic used to be real picky. I dunno if they still are. Both surfaces needed to be machined flat, otherwise they leak.
    Headgaskets will "push out" when you make enough power. THEN you go to metal Bad tuning will blow head gaskets too, and metal will take more before it blows.
    Aug 2010
    Geoff
    mt dandenong
    toda makes/made them too.
    i'd go for a trd one, easy to find,cheap and proven
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I have the the TRD gaskets for $99 now, 3 left I think
    Tim?
    Wild West
    That is ridiculously cheap Sam!
    gawler area.
    i had a trd .5 metal gasket and had it put on properly but just had drama's with it leaking so i thought i might see what else people was running. what size is the ones your selling sam ?
    hachi roku
    Gunner
    Id be looking for issues with your head and block (poorly machined/prepped, warped etc etc) before blaming a hg leak on the gasket.
    Gunner
    Or even head bolts that were out of spec?
  1. 4AGE 20V 0.5mm or 0.8mm HG
    By 70XIN in forum Cars or Parts Wanted
    Last Post: 9th July 2011, 05:56 PM
  2. 20V 4AGE TRD HG .5mm
    By FAST EDDIE in forum Cars or Parts Wanted
    Last Post: 3rd June 2011, 07:55 PM
  3. need a trd 20v .5 or .8 metal hg in sa
    By FAST EDDIE in forum Adelaide & SA Events and Discussion
    Last Post: 21st May 2011, 12:24 PM
  4. 16v and 20v hg the same??
    Last Post: 11th July 2010, 10:41 AM
  5. Are all 4age HG's the same??
    By v-tec in forum Technical - Questions
    Last Post: 18th February 2009, 08:23 PM
