Results 1 to 4 of 4
Thread: Non Toyota question
    Member Anthony13's Avatar
    Jun 2012
    Anthony
    Yarra glen
    Default Non Toyota question
    Hey I no I should prob just post this on a deferent forum but is there any one on here that's familiar with the sr20det I've got an s14 and I noticed that there's been a wire that's burnt out I think it's an earth wire but not sure exactly that's how I found it it connects to some bracket on the firewall and then I think It runs to the coil packs but not sure
    Some help as to what this wire does would great and why is completely fucked!
    Senior Member pt_y2k's Avatar
    Paul
    Just looks like a small earthstrap. Common cause for this to happen would be your main earth straop from chassis to gearbox might have been left off at some point,causing this small wire to take the load during cranking....fit a decent earth strap and replace the damaged one and you should be fine...!
    Jun 2012
    Anthony
    Yarra glen
    Yeah I was going to replace this one and re earth it somewhere better in the engine bay I'll also double check all my other earthing points while I'm at it! But it's raining now would be a perfect time to go for a drive to (^_^)
  • #4
    Veteran Skylar's Avatar
    Ken
    That's just the usual back of head earth wire. Cause is as oer pt_y2k.
    Get a voltage stabiliser and ground kit on the car STAT.
  • Similar Threads
    1. Toyota motorsports NZ - Toyota 86 Build
      Last Post: 13th October 2012, 01:21 PM
    2. Toyota 86 vs Toyota ae86
      By cswan in forum Toyotas in the Media
      Last Post: 6th August 2012, 03:16 PM
    3. Toyota 3ys (2.0 carby) question
      By RyGuy86 in forum Technical - Questions
      Last Post: 10th November 2010, 12:31 PM
    4. Quick clutch question and spigot question
      By wideslider in forum Technical - Questions
      Last Post: 9th August 2008, 12:45 AM
