Results 1 to 3 of 3
Thread: ke70 fuel sender resistances?
    Feb 2012
    Jake
    Wanneroo
    Default ke70 fuel sender resistances?
    Car - 1984 ke70
    part in question - fuel sender
    problem - trying to adapt my fuel sender to suit my s13 cluster. I have found the resistances of full, 1/2 and empty for the s13 sender but cannot find the same for the ke70. does anyone know these or have a service manual that states these values?
    thanks
    Veteran timbo's Avatar
    Tim?
    Wild West
    Not sure where you would find them but maybe try AE71 in your searches, I *think* they would use the same sender. I know the AE86 sender has a different plug but they might be the same too. I look forward to your discoveries as I need a new sender for my 86 but I don't want to pay $150!
    Feb 2012
    Jake
    Wanneroo
    Ended up finding a source that stated 3ohms as full and 110ohm at empty, but was having trouble matching this up with mine. Found a dodgey connection in my sender so soldered a new piece in and it gave me close to that. ~6-106
    so ill put a 300ohm resistor in parallel which should give me similar to the s13 gauge readings of 4-80
  • Similar Threads
    1. Ae86 fuel sender
      By irl86 in forum Cars or Parts Wanted
      Last Post: 30th November 2012, 10:13 AM
    2. JDM fuel sender
      By LittleRedSpirit in forum Cars or Parts Wanted
      Last Post: 29th January 2009, 12:46 AM
    3. Fuel Sender
      By DRF786 in forum Technical - Articles
      Last Post: 26th September 2008, 04:18 AM
    4. JDM Fuel tank, fuel pump and sender wanted
      By Toyo86 in forum Cars or Parts Wanted
      Last Post: 9th August 2007, 10:10 AM
    5. fuel sender float
      By DRF786 in forum Technical - Questions
      Last Post: 2nd November 2006, 04:06 PM
