Results 1 to 10 of 18
Thread: Tips to make exhaust around the 92-95 db mark
    Veteran anastasios's Avatar
    Taz
    Earlwood
    Default Tips to make exhaust around the 92-95 db mark
    Hi all,
    Will be taking my 71 to Marulan on the 21st.
    It has a stock bluetop with pod filter and exhaust.
    Exhaust wise i have 4-1 extractors, one resonator then one high flow muffler. I have a flange before the diff so i can get a quieter muffler/silencer on there without major hassles.
    What are your experiences? Will a stainless muffler be quieter than a mild steel? What would be least restrictive on performance? Extra high flow muffler in middle or quieter rear muffler with silencer?
    these are the rules of Marulan:
    Test 1: Maintain 5000 rpm for five seconds. Requires a reading of less than 92db when measured 5m directly in line with the exhaust tail pipe.
    Test 2: From the same position, return the engine to idle rpm then flatten the accelerator to 5000 rpm for a reading of less than 95db.
    http://www.ae86drivingclub.com.au/fo...read.php/72544
    Link in there has a silencer link on ebay which isn't too restrictive , screws onto the tailpipe.
    Center muffler and rear muffler generally works well.
    Gone
    Joel
    Picton
    Test 2 is BS... how can that be controlled?
    50 rpm could put it over the limit.
    Stainless has a tinnier sound.
    mild steel you get a bit more beef
    Id say if you had a good hi flow muffler...
    make sure its of decent size and not some chinese job... japs are ace at making exhaust systems flow, sound great and quiet at the same time.
    your hot dog or resonator will cut about 3db.
    the positioning of the muffler also makes a difference to how affective it is.
    i think from memory... the close to the engine the more affective... just confirm that though..
    if you have an I phone.. you can download a DB meter app.... will give you some idea of how much noise its making once done.
    You also need to ask the Weighting the DB meter is set to.... A, B or C
    usually the standard is A, it give an average reading and is a fair way to measure.
    Veteran NIZLAH's Avatar
    Niz
    South~Slide Briz
    hot tip, that iphone app is fail -
    I'm looking at ways to bring my exhaust level down also, can't fit anything else in the system as I made the exhaust sit nice and tight to the body, already has a 'flowmaster' resi (interesting design compared to your normal straight through type resi's) I thought it would be a lot more effective than it actually is.... at the rear I have a powerflow straight through offset muffler finished with about a foot of 3" pipe. this all on a 20v, whole system is stainless.
    I can't justify the cost of those apexi ecv so I'm going to attempt to make my own from a throttle body butterfly of the right size, I think Ive got it sussed, but until I have it in front of me the brain will come up with some way of making it work..
    Best bet is something similar, or the biggest muffler you can fit under/in there.. good luck
    BENT MECHANIX - Garage 20:
    Gone
    Joel
    Picton
    not sure if X force are still making those Varex mufflers..
    it depends which one you have ( iphone app ) some of them are fairly accurate.. within 2 db or so
    in no way am i saying its a reference, but it give you an idea.
    also id stick with a 2.25" main system... any more and your just making noise with a low/mild powered NA.
    rear section take it out to 3"... but only a few ft from the end
    Adan
    Oxley Park
    I found having a muffler closer to the rear made it more quiet.
    But nothing beats a decent flowing baffled muffler. Or offset to offset straight through might do ok.
    I have 2 offset to centre straight through mufflers and Id say I only just meet those requirements...
    Veteran Konakid's Avatar
    Henry
    Eastern
    Cat converter, one hotdog/resonator before diff, then high flow baffled rear muffler (not a cannon) my car is super quiet mainly because the exhaust tip dumps to ground 60 degrees or so.
    In Odaiba for the D1 Grand Priox the cars had to be made quieter due to the public so everyone welded on exhaust tips that basically dumped paralell with the ground (90 degrees) i'd say do this with your current setup and you'll have no issues. the ground must absorb the sound waves where as with a striaght tip they are sent outwards through the air.
    Taz
    Earlwood
    okay well i pick up my dizzy today and will test with an app called sound meter on my sgs2
    i like the dump tip idea as it is the easiest/cheapest method i have heard so far
    what about unbolting my rear muffler at the flange and putting a plate in there with holes between the flange?
    Adan
    Oxley Park
    what size tip do you have on the end?
    I have a 2.5" silencer I made up which just slides onto the end if you want to use it. It has holes and scotchbrite to muffle it a bit.
    I find that hotdogs cause drone...
  1. Exhaust tips for my ke70 wagon?!?!
    By kyle unwin in forum Technical - Questions
    Last Post: 9th August 2011, 01:42 PM
  2. [SA] JZX90 mark ii, 1jz, 5speed, fmic, ohlin coilovers, exhaust, etc
    By mark ii in forum Cars for Sale (Toyota Only)
    Last Post: 22nd June 2011, 12:50 AM
  3. S.A. QFM A1RM pads - DB 398 - AE86 front, new in box
    By markiitourerv in forum Car Parts For Sale
    Last Post: 23rd February 2011, 11:29 PM
  4. SA - 2.5 inch exhaust, Big twin TIPS
    By James86 in forum Car Parts For Sale
    Last Post: 14th December 2009, 12:43 AM
