Results 1 to 10 of 12
Thread: 7ag 20V - which timing belt?
    Jun 2009
    Grant
    California
    San Jose
    USA
    Default 7ag 20V - which timing belt?
    Hi guys,
    I'm really busy at the moment building a 7a with blacktop head. The build is very similar to 70xin's build on here. The difference is I am using ae111 oil pump and hydro tensioner. In his thread delazy I think mentioned using a 16V TB with this combo. Can anyone confirm that this is the right belt to use with a 7a block, ae111 oill pump and tensioner, and 20V head?
    Thanks,
    Grant
    Ill confirm tomorrow 100% but have been told it is the 16v 4age timing belt. Though a couple of people have said the blacktop tensioner could be a bit tighter as the belt feels a tad sloppy.
    Seamus
    Milton
    Yep, with that combo it's a 16V belt
    (Mine was different because i used a 16V/7AFE oil pump and tensioner)
    ^ Clicky clicky!
    Jun 2009
    Grant
    California
    San Jose
    USA
    Hi Seamus, did you end up using factory main bolts? Is it important do you think to go with arp studs here?
    The blacktop belts are already kind of slack with the ae111 tensioner. 16V belt with ae111 tensioner on 7ag 20v is more slack than this even?
    Seamus
    Milton
    Hey grant. I used factory main bolts. I'm yet to see a motor that has a 'need' for anything better
    And i can't comment on the next question. You're best to ask 'delazy' (or even look in his build thread, on some of the more recent pages) - i think he has made/purchased a nut/bolt adjuster that fits inside a gutted AE111 tensioner - just to be on the safe side.
    ^ Clicky clicky!
    Yeh, check my build thread...more recent pics tell the story...
    Senior Member LEVIN86's Avatar
    Nam
    Westside
    I have a 7AGE with a 20v Silvertop head...My friend and I recently did a rebuild on it and I got new belts for it. I don't know much about engines but here are some details from my build.
    - 20v Silvertop head
    - 7A stock block
    - 7A stock rods and 20v Pistons (I got new rungs too)
    - Timing Belt = Gates PowerGrip HTD (Made in Germany) 5131 - 115x3/4" 28 116AG
    - Alternator Belt = Dayco Poly-Rib 5PK0825 325K5
    - New T3 pulley kit (Crank, Alternator, Water pump)
    I'll put up a build thread soon of what I did, seems kinda dodgy and cheap because we did a back yard job on everything. Hope this is a little help. The guy at Bursons told me the timing belt comes from a Renault (I think he said 89' model)
    -ae111 head
    -toda ae111 cam gears
    -7afe block
    -ae111 20v oil pump
    -toda 16v belt
    -uber expensive manual belt tensioner
    Surely you could have made that delay-zay?
    Veteran pen15's Avatar
    Mathew
    Sutho Shire
    i have made one for myself but as for the belt and my boss uses a Peugeot 206 gti belt makes everything line up sweet
    the dyno pull to 300rwkw
  1. timing belt and tensioners in bt 20v???
    By slider4life in forum Technical - Questions
    Last Post: 8th April 2010, 07:26 AM
  2. aftermarket ST 20v timing belt number
    By hachi_dk in forum Technical - Questions
    Last Post: 15th March 2010, 09:56 PM
  3. Performance timing belt for 20v silvertop
    By DRFT - 86 in forum Technical - Questions
    Last Post: 22nd June 2008, 12:13 AM
  4. 20V Timing belt Teeth #?
    By 70XIN in forum Technical - Questions
    Last Post: 10th May 2008, 01:01 PM
  5. 20v timing belt
    By DRFTAE86 in forum Technical - Questions
    Last Post: 15th March 2006, 03:25 AM
