Results 1 to 3 of 3
Thread: jdm 4age water setup into RWD 4agze?
    Rudi
    Queensland
    Mooloolaba
    AUSTRALIA
    Default jdm 4age water setup into RWD 4agze?
    Hey gang,
    Would this rwd water setup fit into a 4agze rwd engine config?
    http://www.ae86drivingclub.com.au/fo...nversion-Parts
    Not sure if the belt will be the right size of if any of the hoses will hit on the supercharger?
    Veteran Nikkojoe's Avatar
    Tom
    4agze setup wont allow you to run the rwd 4age water setup because the rear housing with the thermostat will hit the charger, as well as the bypass pipe(s) and top water outlet.
    The only things you can use are the rwd water pump with the rwd water pump pulley to run a clutch fan, as well as the rwd rear head outlet.
    See here for more info: http://www.ae86drivingclub.com.au/fo...e-developement
    Rudi
    Queensland
    Mooloolaba
    AUSTRALIA
    Cheers mate!
    Very helpful!
  1. WTB: 16V 4AGE RWD Water setup
    By Undeez in forum Cars or Parts Wanted
    Last Post: 25th August 2012, 05:26 PM
  2. Replies: 4
    Last Post: 18th June 2012, 03:29 PM
  3. RWD water setup
    By wanted_ae86 in forum Technical - Questions
    Last Post: 11th May 2012, 09:26 AM
  4. Wtb: jdm rwd 4age aircon setup
    By DR86FT in forum Cars or Parts Wanted
    Last Post: 14th January 2011, 07:10 AM
  5. RWD 4age/4ac water pump setup
    By paul123 in forum Cars or Parts Wanted
    Last Post: 23rd August 2009, 07:27 PM
