Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 23
Thread: What’s the difference between an r154 and r155 gearbox
    Senior Member KE70GT's Avatar
    Gavin
    kilmore
    Default What’s the difference between an r154 and r155 gearbox
    Apart from the gear ratios what’s the difference between these gear boxes can they handle the same amount of power?
    Jake
    Northgate
    R155 is from late model hilux I am pretty sure, I am using one behind my 1UZ cheap as chips, can but 3 or 4 for the price of 1 R154.
    Gavin
    kilmore
    Exactly there heaps cheaper I’ve driven a few Hilux’s and they change gear very nicely just looking for a gearbox to put behind a beams that I can punish every day R154 seem like strong gearbox but they cost too much and they’re getting old
    Might be worth the punt, given a r154 sets you back around $2500. Are the bell housings the same?
    Glenn ke_70's Avatar
    Clay
    Barossa!
    are they common?
    and as matt said same bolt pattern for both sides of the bell housing?
    Jake
    Northgate
    Well they still make them new at the moment... I thought a average R154 was around 1500, well I could buy about 5 R155's for 2.5k, haha. It didn't matter to me with the bellhouseing because I had to use custom one anyway with 1uz.
    Jake
    Northgate
    R155 and R155F
    1st 3.954
    2nd 2.062
    3rd 1.436
    4th 1.00
    5th 0.805
    r154
    1st 3.251
    2nd 1.955
    3rd 1.310
    4th 1.00
    5th 0.753
    Gear ratios.
    Plus you can get these if you really need them - http://cgi.ebay.com/ws/eBayISAPI.dll...tchlink:top:en
    I would rather just bend the shifter back a bit though...
    Veteran blake.'s Avatar
    Jun 2009
    Blake
    Penrith
    Ratios look better in the r155, espesally for a 1uz or so thing else with a lot of torque.
    bursting ovaries since 92'
    May 2012
    ACT
    belconnen
    That low ratio 1st gear on the R155 looks like it'd be really annoying on any performance engine.
    Is there anything wrong with using a W5x box? If they can handle the torque of an NA 1UZ I'm sure they'd be fine for a beams.
    Mar 2011
    Ali
    I'm using a W57 behind a 1uz in my current 2WD Hilux build, and apparently they are more then up to the job.
    If you take a look at Lextreme forums, W Series are the most common box used behind 1UZ, and good for up to 300+hp set ups with mountains of torque.
    W57
    1st 3.285
    2nd 1.894
    3rd 1.275
    4th 1.
    5th 0.861
    Rev 3.768
    I'll let you know how good they are in a couple of weeks, just got the engine/box and shaft mounted yesterday and have started to wire it up now.
    Ali.
  1. WTB r154 gearbox.
    By kyle unwin in forum Cars or Parts Wanted
    Last Post: 23rd July 2012, 10:48 PM
  2. R154 JZ gearbox CHEAP, GOOD!
    By LS1silvia in forum Car Parts For Sale
    Last Post: 14th June 2011, 05:45 PM
  3. Replies: 2
    Last Post: 13th February 2010, 12:27 PM
  4. ke70/ae86 gearbox difference
    By dr1ft-pig in forum Technical - Questions
    Last Post: 10th October 2006, 07:46 PM
