Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 25
Thread: 20v Shooting flames out of intake
    Hair model Jacobxxx's Avatar
    Jacob
    Sunshine Coast
    Default 20v Shooting flames out of intake
    Car - KE70
    motor / part in question - Blacktop 4AGE 20V
    problem - First car wouldn't start, finally got it started, try to put throttle down to rev a little bit, car basically dies then just before its about to conk out and turn off it pops some major flames out through trumpets and slowly struggles to build revs and eventually gets up higher in rev range.
    occurs/started when (if applicable)- tried to do burnouts
    personal situation (if applicable)- just want to compete in summernats, not being able to rev is making it difficult to win burnout comp.
    Yeah, seems broken as, what would make it do this? Timing?
    Elite rthy's Avatar
    Leo
    Tulla
    sounds like badassery, just drive around with no bonnet shooting flames out from the intake
    edit:
    timing or ignition
    Aug 2010
    Geoff
    mt dandenong
    This happened to Nam (Levin 86) once, set his quad socks on fire. Sorry I have no idea. Im guessing timing/injector issues
    Standard ecu?
    Jacob
    Sunshine Coast
    Yep standard ECU
    Glenn ke_70's Avatar
    Clay
    Barossa!
    timing both ing and cam, mostly cam
    firing order
    extreame over fueling
    quad alignment
    injector seals mabey?
    if all the rest check out start checking all sensors reltive to the above
    this was basically the main useful points when my beams was fucked at the start and shooting flames.
    my bet is on cam timing
    this was basically the main informative
    Senior Member pt_y2k's Avatar
    Paul
    What dizzy kit you running? Sounds simply like your firing order is out?
    Jan 2012
    will
    Byron Bay
    Standard dizzy location.
    Aug 2010
    Geoff
    mt dandenong
    Before you fix it get a video of it, would make a nice .gif.
    Maybe your vvt is fucked hence why it takes ages to rev and cam timing is out allowing this to happen
    Senior Member davidgarratt's Avatar
    david
    morayfield
    Tps maybe? My 16v that runs quads and razorback ecu ran tps only ant the pickup for the tps didnt make contact until 20% throttle, when it would run it ran like shit the same way you described. I adjusted the point where it first makes contact and is sweet as now.:o
  1. Using a nissan GTIR intake on a 20V
    By Sam-Q in forum Technical - Questions
    Last Post: 26th May 2014, 08:43 PM
  2. WTB: 20V adjustable intake gear
    By Grant #2 in forum Cars or Parts Wanted
    Last Post: 10th November 2011, 01:02 AM
  3. Kings Cross shooting
    By Bart in forum Offtopic Discussions
    Last Post: 25th May 2009, 08:49 PM
  4. Correctable flaw in the 20v intake design?
    Last Post: 12th February 2009, 12:11 AM
  5. Part number: 20v intake gasket
    By skit in forum Technical - Questions
    Last Post: 10th October 2007, 08:58 AM
