same as stuck open top feeds
Check your injector seals too... Come to think of it my ae82 sedan was doing similar things and when i removed the spark plugs after running it for a few seconds i saw this....
It'd struggle to start and when it did it ran like shit...
Bear in mind, this setup has since ran fine, then back to this, then ran fine etc.. New/different vvt solenoid has been installed. Timing marks looked the good (I was a bit pissed at the time lawl)
Didn't get to get a timing light onto it at any point though.
what fuel reg are you running?
would be worth a check to see if either the lines havn't acidently been swapped or broken...
its mixture or timing... its classic "carbs".... mixture is to lean
Or your timing is to retarded.
