Results 1 to 10 of 10
Thread: KE70 steering knuckles wont come out!!
    Member Alexrex7's Avatar
    Jul 2010
    Alex
    Qld
    Goldy
    Aussie
    Default KE70 steering knuckles wont come out!!
    I am in the middle of putting AE86 front struts in but the standard KE70 bastard steering knuckles are stuck!! i have undone the LCA bolt and the knuckle is able to swing around but i am getting no movement and i have tried nearly everything even got blow torch on to heat it up and help ease things but no go
    Anyone know a trick?
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Have you tried levering up on the steering arm with a pry bar and hitting the top of the thread of the balljoint with a nut on it? Usually does the trick.
    Jul 2010
    Alex
    Qld
    Goldy
    Aussie
    yea mate tried that too ill just have to try a bigger hammer tomorrow i think lol
    Senior Member sleeper_13's Avatar
    Jul 2011
    KE70
    south
    Use a press
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    bash the side of the steering arm with a hammer, has always worked in the end
    Glenn ke_70's Avatar
    Clay
    Barossa!
    yeah thats the proper way to get them out.
    somtimes they're just that stuck! if they havn't come out with heat they must be tight!
    worst case is you could drill them, im fairly sure they'd be drillable
    Michael
    Crimebrook 2749
    leave it in some wd40 over night, but never had one not come out with bashing the arm with any balljoint, you could try press lightly then hit the arm the shock and pressure would move it but never had to do it personally
    Veteran Skylar's Avatar
    Ken
    Pulley remover.
    If you get it lined up right and pulling straight up, it'll make a joke of it. You'll wonder why you ever tried anything else.
    It's like a press that fits in your back pocket.
    Veteran shift_rook's Avatar
    SE Burbs
    Ken's on the money. If you're broke a hammer does work though.
    Senior Member sam92's Avatar
    Jul 2012
    Wagga Wagga
    I put ps knuckles in my ke70 the other week and had the exact same problem just keep hitting it will come eventually
  1. Steering knuckles
    By lappy in forum Technical - Questions
    Last Post: 22nd July 2011, 12:25 PM
  2. Power steering knuckles, interesting...
    By duncan_86 in forum Technical - Questions
    Last Post: 12th August 2009, 11:42 PM
  3. T3 steering knuckles
    By MJ86 in forum General Topics (No Technical Questions)
    Last Post: 14th February 2009, 10:02 PM
  4. f/s ae86 power steering knuckles
    By goofesgts in forum Car Parts For Sale
    Last Post: 7th April 2008, 12:25 PM
