Results 1 to 10 of 13
Thread: cams in a stock bigport?worth while?
    Aug 2010
    Sutho Shire
    Default cams in a stock bigport?worth while?
    hey guys,i have a stock bigport run by stock ecu in my 86 at the moment,im thinking about chucking a pair of cams in it,what can you run in a stock motor on stock management?would it be worth doing?been looking around and got way to many different opinions on sizes,lift etc,car is set up/used for drift regod but rarely street driven if that matters.most common answer i got was you can run 264's on stock management but i duno sounds abit out there
    Veteran Jimmee1990's Avatar
    Mar 2011
    Mt Dandenong
    Depending on how much overlap and lift you run and how well dialed in the cams are makes a big difference. I ran a stock jdm bigport with 270 degree cams and it ran terribly until I played around with adjustable cam gears, after it was all set up properly it went heaps better than before they went in. These were cams designed with running the stock ecu in mind however, so the specs may be a bit different to the typical hks or toda etc cam grinds. Definately good bang for buck if you're going to fit them yourself.
    Aug 2010
    Sutho Shire
    i have some adjustable cam gears in garage for a 7a,they are for a 20 v, are the adjustable cam gears interchangable between 16 and 20 v?is messing around with cam gears something you can do at home and pick up or do you need abit of experience?
    Mar 2011
    Mt Dandenong
    As far as i'm aware the exhaust pulley is the same for 16v and 20v, but haven't ever had them side to side to compare. I don't know what the difference between timing marks for a 7a compared to a 4a would be either. You can play around with cam gears at home, but when I do I always turn the engine over by hand as a general rule to make sure there's no issue with valve to piston clearances, and only make small changes at a time.
    Aug 2010
    Sutho Shire
    thanks,yer just read that, they work on exhaust side and you dont use them on intake side on a 20 v,so the toda gears i have are 16 v,do you know what brand your 270's were?ide like to find some that are compatible with stock ecu
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    yes exhaust cam gear for 20v is same as 16v, inlet isn't obviously
    7a marks??? what cam gears are they, only need to go adjustable cam gear with 7a because the timing marks don't line up, because of the taller block, if they have timing marks 0 should be for a 4a
    Jarrod
    sth adelaide
    I'm running HKS 264 8.1mm lift cams in my bigport with a stock jdm ecu. Its only a track car so i cant comment on how it drives on the street but there was a noticeable improvement on the track. The car idles fine, doesn't stall and gets around the pits no worries at slow speeds.
    Aug 2010
    Sutho Shire
    thanks,thats the info im after,lolwat yer they are toda 4a gears,might try track some 264 8.1mm lift cams
    Mar 2011
    Mt Dandenong
    Mine were done by Clive Cams in melbourne, he grinds them from scratch from new billets. If you wanted to talk to someone there about different options for a 4a, ask for trent cause he's built a few.
    Aug 2010
    Sutho Shire
    sweet,thanks
  1. VVT and cams - is it worth it?
    By 70XIN in forum Technical - Questions
    Last Post: 21st September 2011, 08:35 PM
  2. BIGPORT CAMS
    By AE86dori in forum Cars or Parts Wanted
    Last Post: 20th September 2008, 01:44 PM
  3. bigport cams
    By reecegze in forum Cars or Parts Wanted
    Last Post: 29th February 2008, 02:35 PM
  4. Bigport cams
    By Justo in forum Cars or Parts Wanted
    Last Post: 29th July 2007, 08:05 PM
  5. head gasket might be blown, is it worth doing cams
    By Benno in forum General Topics (No Technical Questions)
    Last Post: 21st August 2006, 04:54 PM
