Page 7 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 61 to 70 of 146
Thread: G Series & F Series Diff Disc Brake Solutions
  1. #61
    Veteran johl's Avatar
    Johl
    how much are people paying for r33 rear callipers?
  2. #62
    Senior Member Skid_KE70's Avatar
    Daimon
    Tasmania
    Launceston
    Na, no spacer and fits one there very well. The R33 Rotor is slightly thicker than the standard hilux drum.
    ---- Fryin Fifth Represent ----
  3. #63
    Daimon
    Tasmania
    Launceston
    Normally $150-$250 a pair from most wreckers etc.. probably cheaper off the net. There are some sweet brake pads available for them, I’m using Green Stuff Pads
  4. #64
    Jake
    Northgate
    Try looking overseas at recoed items I got my MA70 supra calipers for $170 delivered as a reconditioned set new pistons seals and a hone. Could send back the other ones I have to get back the $30 core charge but the cost of postage makes it not worth it, haha.
  5. #65
    West
    Yeah theres a company that recos almost anye caliper you can think of and sells them on us ebay.
  6. #66
    Gone
    Joel
    Picton
    if your paying $200 a set for R32/33/34 rears your paying a premium..
    $150 is what you should be getting them for.
    buy them from the net... dont even both calling a wrecker
    Rebuild kits are cheap as well, its a DIY job as well.
  7. #67
    Glenn ke_70's Avatar
    Clay
    Barossa!
    has anyone ever looked into wrx my99ish rear rotors? 266x18mm 67.5mm offset.
    in just about to start building my rn25 hilux diff (which is g series i think?)
    im converting back to 4 stud and want a duel caliper setup that fits under 14'' wheels and suits the wilwood fronts.
    i also want minimal caliper protrusion.
    i've got 1 set of skyline 2 pots just need another.
    will update this thread with progress.
    car is full track car so no cable hand break needed.
    what meterials are you guys using for caliper brackets? im thinking 10mm mild steel but im wondering weather that would be strong enough?
  8. #68
    Gone
    Joel
    Picton
    10 mm mild steel is BS overkill!!
    each bracket will weigh around 3 - 4 kg!
    i used 10mm ally 2024 and had no issues... bracket weight was around 600 grams from memory.
    your already adding about 40kg with a G series, do you really want another 10 - 15 kg ontop of that?
    you suspension will be up to shit, so much weight it wont be able to handle or keep the wheels on the black stuff.
    The car will feel like a dead weight..
    after you drive a car with massive unsprung weight, then mod it to loose around 6 - 8 kg / corner, the change in handling is outrageous!
    i know you have heard the whole unsprung weight argument before.. and i was one of those who said.. "yeah yeah whatever"... but until you do it to your own car, and notice the difference.... you will never fully understand.
    You need to think about this... design it right 1st... the car is light.. you have a twin piston, larger surface area, combined with a rather large vented/ most likely slotted rotor... and a relatively small wheel/tyre width/rolling diameter
    it will not take much force to lock it up...
  9. #69
    Clay
    Barossa!
    yes unsprung weight is abit of an issue isn't it.
    mabey i could try ally instead. it would be alot easier to make also.
    would 6061 grade do the job?
  10. #70
    Daimon
    Tasmania
    Launceston
    The brackets i made aren’t an overkill, I’d rather something be stronger than it needs to be, and G series isn’t 40kg difference.
    I think it’s stupid to even consider making things out of light weight material, it’s the difference between a fat driver and a skinny driver. We are talking about safety here.
  1. Disc brake rear end & S series ae86 diff
    By drift kid in forum Car Parts For Sale
    Last Post: 24th October 2012, 09:29 PM
  2. Replies: 3
    Last Post: 16th October 2011, 09:05 PM
  3. handbrake cables - T series disc brake diff.
    By NIZLAH in forum Cars or Parts Wanted
    Last Post: 15th October 2009, 09:16 PM
  4. T series Disc Brake Diff - Handbrake cables?
    By NIZLAH in forum Technical - Questions
    Last Post: 13th October 2009, 12:40 AM
  5. T Series Disc Brake Diff Housing
    By ke25 race in forum Car Parts For Sale
    Last Post: 19th March 2009, 10:20 PM
Tags for this Thread
