Page 8 of 15 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 LastLast
Results 71 to 80 of 146
Thread: G Series & F Series Diff Disc Brake Solutions
  1. #71
    Veteran Skylar's Avatar
    Ken
    I did FEA on a 10mm steel caliper mount. 1000kg car, 50:50 weight split (even when braking) slowing down at 1.5g or something. Deflection was 0.02mm. Could easily make it thinner. Too bad my program doesn't have more materials I could model with.
    It has "structural aluminium" but I don't remember if it mentioned what grade it was. This is from like 2 years ago so I'll have to check it again and go looking for more material files so I can model 2024/6061/7075/1020/whatever else that's commonly used.
  2. #72
    Glenn ke_70's Avatar
    Clay
    Barossa!
    i don't think 6061 will cut it.
    i think i'll use 8mm plate as daim has. will probley be largly the same exept to suit a smaller disk.
  3. #73
    Senior Member Skid_KE70's Avatar
    Daimon
    Tasmania
    Launceston
    I can probably make a kit for a smaller diameter rotor for you if you were using the same calipers. i can draw it up on CAD and have it laser cut
    ---- Fryin Fifth Represent ----
  4. #74
    Clay
    Barossa!
    ah its cool, i can get brackets watercut up for less than $20.
    converted the diff to 4stud tonight too.
    made a jig and picked up off of the centre hub and 1 stud
    (don't mind those other 4 holes, just made it out of some junker flanges laying around)
    threw it in the radial drill
  5. #75
    Veteran johl's Avatar
    Johl
    which f series is that out of clay? im interested to know if the rumour is true about there being an extra 20mm of teeth on yr22 axels therefor making it a simple job to shorten the diff?
  6. #76
    Ken
    That's a g-series isn't it?
    Tarago axle has like an inch-30mm of spline. The factory open diff has about an inch or so off memory. A cusco altezza diff however only has like 1/2" to 15mm of spline. Where the two meet and how much you can cut off, I don't know.
  7. #77
    Clay
    Barossa!
    yes this is a g series out of a rn25 hilux. no need to shorten as its like 25-30mm shorter than the corolla diff.
    if the f series axles are similar design to this then yes you can shroten heaps if you wanted.
  8. #78
    Adz
    post removed
    Last edited by Adsport; 6th November 2012 at 01:57 AM. Reason: Handing it over to armchair experts
  9. #79
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    With JDM disc's too it appears the hub on the axles have been machined down
  10. #80
    West
    MX13 diff has the same centrebore as ae86 JDM disc rear end, 60mm.
  1. Disc brake rear end & S series ae86 diff
    By drift kid in forum Car Parts For Sale
    Last Post: 24th October 2012, 09:29 PM
  2. Replies: 3
    Last Post: 16th October 2011, 09:05 PM
  3. handbrake cables - T series disc brake diff.
    By NIZLAH in forum Cars or Parts Wanted
    Last Post: 15th October 2009, 09:16 PM
  4. T series Disc Brake Diff - Handbrake cables?
    By NIZLAH in forum Technical - Questions
    Last Post: 13th October 2009, 12:40 AM
  5. T Series Disc Brake Diff Housing
    By ke25 race in forum Car Parts For Sale
    Last Post: 19th March 2009, 10:20 PM
Tags for this Thread
