Page 1 of 4 1 2 3 4 LastLast
Results 1 to 10 of 33
Thread: RT142 Corona Turbo
    Oldschool Member
    May 2006
    Hornsby
    Default RT142 Corona Turbo
Name:	2012-09-24 15.26.39.jpg
ID:	27250Hi Everyone, Its my first car i have posted on here but i thought it is time!
    I joined this forum when i bought my first ae86 about 5 or 6 years ago, some of you may remeber it,
    It was white, had a 18rg fuel injected engine in it, it was different!
    I sold it and i last i remeber it had a Trueno front fitted to it then a CA18 in it, then an SR?? If anyone knows id
    Love to hear haha, i think it was the only Sprinter in aus with a 18rg in it possibly??
    Anyway, Current Car is a corona. I bought it dead stock off a friend from work, I toy around with welding and
    fab like alot of you guys do thought id have a crack at a turbo!
    I Plan to fit a lsd and have some 15x8 rims ordered for it, i love the shape, I love reading Marv's blog, gives
    me inspiration for my build, good looks,,,,,hopefully!
    Specs are
    *1986 Rt142 Corona
    Engine
    *Factory 22re engine
    *T25 off a 180sx (was told type x but unsure)
    *R32 GTST Aluminum twin core radiator
    *Braided lines
    *2x10 inch thermos
    *600x300 intercooler with aluminum pipe work
    *Steam pipe log manifold
    *3 inch stainless exhaust to cat, stock cat back (not for long)
    *Adjustable FPR
    *D40 Navara 4.0L fuel pump
    *Apexi AFC (not wired up yet)
    Driveline
    *Stock w55
    *Heavy Duty Clutch
    *Stock Diff (want to change Ratio, anyone have a lsd?)
    Suspension
    *Front Struts sleeved
    *Front Mr2 KYB AGX 4 way adj shocks
    *Front 8kg Spring
    *Rear Koni Reds
    *Patrol springs (cut)
    Wheels/tyres
    *Rota Shakotans 15x8 offset 0
    *195/55/15 tyres
    *rear 25mm bolt on spacer
    Anyway here are some pics, ill add more details as i go!
Name:	2012-10-09 12.37.53.jpg
    Here are a couple of build photos, it has a loong way to go my friends!
Name:	2012-08-13 13.49.34.jpg
    Manifold, its not perfect, but i love it, it works.
Name:	2012-01-22 12.33.01.jpg
    3 inch stainless dump, took aprox 35 hours labour to make in spare time.
Name:	2012-09-09 14.52.18.jpg
    Dump pipe.
Name:	2012-09-16 10.55.46.jpg
    Its a tight fit but just a challenge, more to come!
    Veteran joeschmo_57's Avatar
    Joe
    NT
    Nightcliff
    About time someone truboed the RE. I'm sick of hearing people say "Oh yeah, i think i will just put an SR in and be done with it. I don't know if the stock engine can handle it."
    Good work man. How does it drive? Any shots of it a a whole?
    quit hatin get bakin!
    Oldschool Member
    May 2006
    Hornsby
    I really liked the 18rg i had previously and im a fan or the R series engine, there great. I like Nissan, but an sr is not how i want this build to be.
    It is running 7psi, straight wastegate, no boost controller, all i have done is upped the fuel pressure and a new fuel pump. It flys, 10 times better then before! Its still no complete missile but it is very suprising, the engine has 316000km on it, does not use oil or water and i boost it everywhere. Old Toyota's....need i say more? haha
    I'll get full shots when i get my camera off my brother!
    Dec 2011
    Kerry
    Warradale
    good to see another 22rte getting there...
    mark's down here was win, stona kid is turboing his too i think
    will be good to see some action shots/vids !
    Veteran AJPS's Avatar
    Lonsdale
    Quote Originally Posted by Ktas View Post
    marks is now 422rwkw 2jz
    stoner kid has his old 22re+t set up
    good for over 200rwkw
    Aug 2010
    Adrian
    South
    Nice! Good to someone actually doing a 22r turbo, would be something I would like to do to my celica
    Senior Member Wagon86's Avatar
    Feb 2012
    Sa
    seaford rise
    How did u up the fuel pressure. I had a turbo on my 22re for a day till the turbo blew. Was on 6 pound went good for just a shity ct20 turbo. Future plans is to Probs build one to handle more boost. Good luck in in rest of build
    Oldschool Member
    May 2006
    Hornsby
    Some updated Pics.
    Attachment 27356
    Front Fitment, Need to roll guards to go lower
    Attachment 27357
    Rear Fitment, Again need to roll guards to go lower
    Attachment 27358
    Attachment 27359
    Oldschool Member
    May 2006
    Hornsby
    Quote Originally Posted by Wagon86 View Post
    Thanks Wagon86, at first was dodgy and just clamped return line to get it running quick, but now have a Adjustable FPR with a little gauge on it, i found it needed alot more fuel, until i had enough fuel it would backfire through the airbox and run poorly.
    Keen to see some pics of your setup. Do you find the CT20 is to big or small for it? This is similar sized turbo to a T25?
    Feb 2012
    Sa
    seaford rise
    Oh yeah . I've got a malsappi rising rate fuel pressure thin from a previous project .might work. Umm I'd say that the t25 would be better. The ct20 is just a little to all. Spools quick but dies high revs. Probs gonna make an adapter plate to fit a t28.
ID:	27360   Click image for larger version.
ID:	27361   Click image for larger version.
  1. Replies: 5
    Last Post: 18th January 2012, 03:47 PM
  2. Corona RT142
    By Corona w/ Lemon in forum Cars for Sale (Toyota Only)
    Last Post: 28th March 2011, 08:58 PM
Tags for this Thread
