Results 1 to 10 of 58
Thread: THE MOTHERF@%#A..........1UZ RN85R
    Mar 2011
    Ali
    Default THE MOTHERF@%#A..........1UZ RN85R
    1989 Blue RN85R Toyota Lowlux 2WD Single Cab
    Bought with 156,xxx now has 231,xxxkms
    22R Power
    G52 5 Speed Manual
    Stock exhaust with leak
    Custom respray WRX blue with Black bonnet, has 3 layer
    4WD front end, chrome grille and corner lights, cut up rodeo lower apron
    Stock Interior
    18x7 Random alloy fronts
    18x8 Random alloys rear
    Torsion bar front end wound down
    Rear 3" blocks
    Front Shocks are gone
    Rear Shocks are non existent
    Drum brake rear end has new cyl and shoe's, locks up with any amount of peddle in wet with no load
    Stock front brakes, new pad machined rotors
    Picture is from 6 years ago when paint work was done
    22R timing chain guides were on the way out, so I replaced them and new chain, freshened up the motor and sold it.
    Picked up a LS400 front sump UCF11 1uz with full loom and manual conversion
    Pulled out the motor to discover G52 box, not a W series...
    Thought about using G series with the W/R series adapter
    Adapter and G52 (G series, the not spoken about cousin of the W series)
    Shot at 2012-09-08
    Bought a W57
    Adapter and W57
    Shot at 2012-09-08
    A341 Bellhousing didn't want to work
    The with the Adapter bolted up to the W57, the A341 bell fouls on the bottom bolt head.
    Shot at 2012-09-08
    And the 2 widest bolts into the adapter to the box, the heads foul the bell.
    Worked it out
    Howe Hydraulic Release bearing
    Shim kit that came with it is questionable...
    Had to have a 27mm spacer made up to sit this thing far enough forward.
    Picked up power steering box for it, replaced centre rod, steering idler, and inner tie rods while I was there.
    Looks like the Alt may foul the PS box, will mount it on other side....
    W57 bolted up to stock G series mount with minimum modification, had to elongate rear rubber mount holes buy 3mm, tailshaft went straight in same spline.
    Today'sProgress
    Delete everything to do with the auto and don't need.....Mission and a half
    Mar 2011
    Ali
    Anyone doing a 1uz conversion with the stock ecu, take a look at this site
    Everything you need right there.
    More to come.
    Jake
    Northgate
    Saw that website, if I wasn't colour blind and non retarded I could probably work it out. Maybe you could help me wire my T18 when you've done your hilux haha.
    I also thought about putting a 2wd 1uz in a hilux to tow my T18 with but I wanted a 4x4 and diesel and ended up getting a turbo 80 series.
    Mar 2011
    Ali
    Yah, I would be happy to help out man, serious.....just got to get mine mobile so missus stops complaining 1st......
    What is your 1uz out of?
    If its 95 on non vvti soarer that site makes it very easy.
    80 Series are a rig.
    I originally started the swap for tow rig, but I think i'm actually going to register the panno....
    Jake
    Northgate
    I got mine out of a 91 celsior so no immobilisers to go through being an import engine I think. Mine only needs the most basic wiring, haha. Just a button to start it that's about it. Plus all the other wiring I could probably do myself.
    Mar 2011
    Ali
    91 Celsior would be very similar to what I'm doin.
    Mine is 92 Celsior, but is Aus delivered, no traction control, no speed limiter and no immobilizer...
    Does your ECU have 4 plugs, 26pin, 16pin, 22pin and another 26pin that looks the same as 1st one, but is upside down?
    And do you have all 4, coz you need them!
    I'm one short, but devised a method using a AE92 4agze 26pin with filed down locating lugs
    Jake
    Northgate
    ill have a look when I wake up.
    Mar 2011
    Ali
    Today was pretty uneventful.
    I removed the upper manifold so I could delete more wires.
    I did however get the alternator on and the p/s pump with out fouling the Rn85 p/s box....All good. Pretty happy with that!
    Jake
    Northgate
    Sounds good, I have no other accessories other than alt anyway haha.
    Mar 2011
    Ali
    Has your 1UZ Alt got big round plug or oval?
    T18 would have had external regulator.
    Do you still have the wiring for that?
  1. 1UZ manual Conversion OR R154
    By jakel in forum Cars or Parts Wanted
    Last Post: 20th November 2011, 12:15 PM
  2. 1UZ Wiring Diagrams Needed
    By PRIMRK in forum Technical - Questions
    Last Post: 13th November 2010, 10:52 PM
  3. 1uz V8 Hiace
    By Clutch_Happy in forum Cars for Sale (Toyota Only)
    Last Post: 28th December 2009, 10:57 AM
  4. mx83 cressida 1uz
    By grimley in forum Cars for Sale (Toyota Only)
    Last Post: 3rd August 2009, 12:13 PM
  5. 1uz
    By tyrone098 in forum General Topics (No Technical Questions)
    Last Post: 24th January 2009, 02:29 AM
