Results 1 to 10 of 15
Thread: Rosejoints - Good & Bad?
    Eastside
    Default Rosejoints - Good & Bad?
    Hey guys,
    Just a question in reguards to Rosejoints/heim joints. I just would like to know the pros and cons of having them in a street car over conventional setups. As I've seen alot of adjustable lca's (which I'm interested in) panhards, tie rods etc. Or is it better off left to "track cars"?
    Cheers Ben.
    Veteran johl's Avatar
    Johl
    in my old street car i went from normal trailing arms to adjustable rose jointed items and the difference was amazing. it wasnt loud and clunky like everyone thinks it is. however i still had a full interior and sound deadening so that may have helped the noise.
    for my current build i have rose jointed lca, trailing arms and panhard rod but i havnt driven it yet so cannot comment on how good/bad having all rose joints is.
    Member 96sonataBro's Avatar
    Mar 2012
    Hugo
    W.A.
    s.o.r
    the purpose of a bush is to absorb shock at the loss of response. Rose joints being solid, give you the most response but transmit 100% of the shock to the chassis. This makes them ideal for track, or if your state has nice smooth roads. i cant speak for vic but in w.a. all the roads in my aria are shocking so any rosejoint products would shake the car to pieces if being daily driven. and i have heard that they work alot better for horizontal movement(lca/panhard) but i don't no why, can anyone confirm this ?
    Moderator Frak's Avatar
    Jamie
    Put small bags over the joints to keep road crap out, Cusco have rubber boots around theirs that work well, water + road grime = worn out rose joint. I have rose jointed lower arms, caster rods, upper/lower arms/ panhard rod and works good.
    Hachiroku since 1994
    Veteran Rice86's Avatar
    Richard
    Liverpool
    all my stuff is rose joint too in my daily ae86, they bind and clunk when driving up my drive way on an angle.. they make more noise the lower your ride height goes when not setup up right, when they are set up close to being right they produce less clunk but will still make some noise..no tyre noise though, only when shit binds
    this is all from the rear diff, up front Ive had no issues at all that i can think of
    dose
    Mar 2012
    Hugo
    W.A.
    s.o.r
    on the subject, does anyone no where to get cheap heim joints + bung kits that are not shit, or should i just stick to the yank sights
    Jamie
    Richard I'm running equal length rear so no problems with binding, if I was running unequal I'd only rose joint the lowers and run rubber in the top arms. After running equal length rear that's all I'd ever do on a lowered 86, the difference is unbelievable.
    Richard
    Liverpool
    Quote Originally Posted by Frak View Post
    i would go equal if my car was a 2 seater daily, but for now I'll just have to deal with the binding and the cons of being a road car.
    dose
    Personally i wouldn't use them in a road car....
    Moderator Sam-Q's Avatar
    Endeavour Hills
    I agree with Frak, don't run rod-ends without a boot, it's like running an open bearing.
  1. SOLID engine mounts.. d good or d bad
    By D86TOY_20V!nce in forum Technical - Questions
    Last Post: 5th November 2007, 05:42 PM
  2. what so good/bad when your 5th gear is like a 4th??
    By FoB_aE8866 in forum Technical - Questions
    Last Post: 13th October 2007, 03:45 PM
  3. First the Good news, then the bad...
    By ke70_sa in forum Technical - Questions
    Last Post: 29th August 2007, 02:44 PM
  4. good or bad
    By blu 86 in forum Technical - Questions
    Last Post: 28th December 2005, 07:38 AM
