Results 1 to 10 of 19
Thread: removing front rotors
    Default removing front rotors
    I've just taken off the caliper but have no idea how to remove the rotor. there appears to be a strange, large metal cap over where the centre bolt should be. Do I need to remove it? If so how?
    Senior Member dave2221's Avatar
    flat head screwdriver and do it like a tin lid
    then remove the split pin, undo the greasy bolt and your entire hub will come off.
    Veteran hao.'s Avatar
    Hao
    South Brisbane
    edit: lol. what dave said ^
    Gone
    Joel
    Picton
    then take off the 4 bolts mounting the disc to the rear of the hub.
    dont loose the locking cap and the washer that sits between that "strange metal cap" and the outer bearing.
    Veteran slide86's Avatar
    Huw
    Hills
    it is VERY important that when you refit the hub back onto the stub axle, you tighten the nut correctly.
    this doesnt mean doing it up tight as possible, as that will fuck shit up in a big way.
    you need to do it up enough to remove the freeplay in the bearings, but not too tight as to crush them in the hub.
    one way to do it is, do the nut up finger tight and then give it a 1/3 to 1/2 more turn with a shifter...back it off...then repeat. just remember, dont overtighten this nut!!!
    thanks for the replies.
    still can't get it off though. I can't get a flathead in anywhere there is no gap. Or do I have to force it in with a mallet?
    Jun 2009
    Ken
    Liverpool
    Would someone post up a DIY with pics would be great or a link would be great as well. I'm looking at replacing my front rotors soon.
    Thanks in advance.
    Huw
    Hills
    have you actually got the hub and disc off the car?
    Senior Member Dylan's Avatar
    Dylan
    this help?, probably easier than explaining it
    well i am assuming you have already got the wheel off..
    there is a gap.... find it you, my padawan
    here is one i prepared earlier,..... and thats the split pin and the bolt you have to undo
  1. Replies: 30
    Last Post: 4th July 2012, 10:40 PM
  2. Removing front springs
    By doridori in forum Technical - Questions
    Last Post: 8th March 2009, 01:27 PM
  3. Removing front windscreen
    By marco in forum Technical - Questions
    Last Post: 17th April 2008, 08:17 PM
  4. removing front guards
    By driftster in forum Technical - Questions
    Last Post: 28th September 2006, 08:42 PM
  5. removing front bumper
    By ke25 racer in forum General Topics (No Technical Questions)
    Last Post: 30th May 2006, 06:45 PM
