Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
Thread: Trueno street/track 3SGTE build
    Feb 2012
    adam
    nsw
    glenmore park
    Default Trueno street/track 3SGTE build
    hey guys, iv been building this adm sprinter for about a year and a half now, never ending project with the usual headaches and speed bumps along the way keeping it from getting finished. and aprenticeship wages didnt help
    all of the work has been done by myself and a couple of mates pitching in here and there to help me out
    but anyway ill post some pics for u all
    sorry for the amount, its from another members rides forum i have going atm
    here u go!
    The scary new start, Ground up build!
    Sprinter, 83, stock as a rock:
    to start. front end:
    Jdm sway bar 25mm
    New nolathane bushes all round
    Jdm custom coilover fronts
    Tokido inserts
    Unknown jap camber tops
    Unknown spring rate, guess atleast 12kgs or so, all i no is there stiff as fuck
    25mm bolt on spacer
    Jdm brakes
    RCA's, also soon to have ajustable LCA's
    Jdm rear diff, disk rear end
    TRD tight 2way LSD
    TRD Blue shocks
    TRD springs, once again unknown spring rate but stiff as fuck also
    AJPS panhardrod
    How it sat on my Hayashi Streets
    Ducktail wing also
    The 4ac, excelent condition
    Body work starts!
    Trueno front end from the track car
    Bolt on flares fitted
    Doors fully paint stripped, repaired and hifilled!
    Replaced the passanger quater as it was badly damaged as he was a wet slide king
    Also cut and welded for flares
    Paint stripping stage, getting ready for repair
    Lights mounted and working
    Finally at the paint stage, edging out
    Custom 2pac Red, Based off a Honda Red, with a coat of clear over the top for more depth and shine
    Prep stage, outer rubbed and ready for a squrt
    Painting stage
    Ground coat
    All done!
    3 coats of colour and Clear as a finally coat
    Finally at home the first day
    Seat rail finished
    Carbon fiber Cobra
    getting the interior done
    Jdm dash cluster
    Interior pretty much finished for now
    Engine bay prept, masked and ready
    2 thin coats of primer to seel it off
    Basecoat and clear, all finished off
    Painting all the brack, clutch and fuel lines
    Engine ready to drop in
    Head lights painted black. Coz I can
    headlight wiring
    Wiring done, most all hidden, all brand new, but left open atm for when we the engine is ready to start we can test it all wires if there is a problem firing
    One wire for fuel pump
    Alternator, and water temp
    Decided to leave thw battery in the front, easy to get to
    Glad I dont do this shit lol
    Will be cleaned up once it starts
    Wires and relays for trueno lights
    Felt like painting the light surrounds
    Sparco removeble boss kit, nice and close
    Restoring begins!
    Picked up my jap Jasma equal length 4 to 1 extracters
    New jasma exhaust, 2 1/2" with 5zigen cannon, sounds nut
    Carter gold fuel pump
    Kouki front bar and lip, front lip.needs alot of work
    May just buy.a trd lip instead
    Set of Yokahama Advans, still new only used once
    Managed to pick up for a good price
    195/60/14's
    Bonnet pins, and bonnet fitted today, sits nice with the bonnet lock actually working
    Freshly polished Hayashis with the Yokahamas
    Fit nicely
    Exhaust finished, added flex pipe yesterday as someone cut the cat out and mounted a dogey piece in, also shortend hangers to lift it, so.now sits nice and high and doesnt move at all
    Mounted front bar, beem to lazy to paint just yet lol
    Nice to see it of the front lawn!
    Engine bay completed, wiring done and all hidden amd cleaned up and fuel lines finally sorted with new carter black and fuel reg
    back from my europe tour and back on my feet ready to get back into the 86.
    Decided to pull the old 4age out and donate it to my mates nuts ke70, craving more power.
    Loved the N/A power, sound of 10,500rpm and the old school carbies but needed a change.
    So i have picked up a Gen4 3sgte to replace 4a
    Striping it down and going from there. Will be keeping internals stock as for now till i decide on more power.
    There is a few little bits and pieces that needs to be fabbed up such as the drivers side engine mount, cooling system, intake and turbo manifold. Im sure there will be plenty more along the way!
    Grabbed two 2s mounts from an old corona from a wrecker, turns out it Bolts straight in besides 2 bolts on drivers side. So a plate will be made up.
    I have a W58 bell housing, for late model 5 speed supra box. Looking for a box atm!
    Also a Hilux diff, just need the mounts welded on.
    Will be running custom rear brake setup, back to 4 stud. Going to try keep the size of brakes to fit in 14's as i want to still run the Hayashis, but not going to hold my breath as i dought ill be able to with decent brakes.
    Few more plans here and there
    Will be alot to do but will try keep the updates coming!
    Finally decided to give in and get rid of the polka dots!
    black suede much nicer
    New recaro seat for passenger
    big mess
    striped down, first test fit
    sits a little high. hopefully by just changing the rocker cover will sort it out
    also shaving most the engine bay of any unnecessary holes, battery tray etc
    in progress atm.
    all wiring will be hidden aswell
    picked up a ct26 7mgte turbo to use the rear housing for the 3s st26
    thats it for now guys
    hope u all like!!
    adam
    Veteran johl's Avatar
    Johl
    wow. great build. one question. the engine bay colour is really nice but why didnt you paint the engine bay in the same red as the rest of it?
    Feb 2012
    adam
    nsw
    glenmore park
    thanks mate
    um just wanted to do something different i guess
    Veteran haveaparty's Avatar
    Mar 2010
    Brett
    Crestmead
    Looks nice man. Love seeing a build go from nothing to... Well this lol. Good work.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    i thought you bought ANOTHER sprinter, was thinking WTF!!!!!!!!!!!!!!, hahahah lookin good man
    Feb 2012
    adam
    nsw
    glenmore park
    Haha thanks guys
    Much much more to come over the next couple months!
    Senior Member t-nol's Avatar
    May 2010
    Trent
    Isn't the Gen 4 3SG a BEAMS? Thought only earlier ones are turbo'd. Nice job so far, i like the engine bay different like that, and glad you binned the polka dots, lol.
    Feb 2012
    adam
    nsw
    glenmore park
    nah this is a Gen 4 from a caldina, has coil packs from factory and different cams to a gen 3 and different turbo etc
    thanks man, and yeah the polka dots had to go lol was funny for a while though! good for a laugh and to irritate the haters
    picked up this today!! hope it fits
    should be good for the 300rwhp im aiming for!
    hopefully sunday get some more engine bay stuff done, welding up holes etc
    cheers
    Michael
    Crimebrook 2749
    the riff is stepping up, this thing , 4g63 for me and blakes going dirty dirty engine
    Feb 2012
    adam
    nsw
    glenmore park
    haha yeah man, good comparison between all 3
    and craigs ke. getting my old engine with itbs
    wil be the perfect ke70 once finished
  1. Tas Ae86's - Trueno Track/Drift Car Build
    By Tas AE86 in forum AE86 Owners Forums
    Last Post: 24th October 2012, 06:16 PM
  2. Max Haggard's KE70's - Track Vs Street
    By maxhag in forum KE70 / AE71 Owners Forums
    Last Post: 16th April 2012, 03:08 AM
  3. Chris' Street/Track Ke70
    By Chrisrundell69 in forum KE70 / AE71 Owners Forums
    Last Post: 9th August 2010, 08:37 PM
  4. AE86 For Sale / Track or Street
    By RyGuy86 in forum Cars for Sale (Toyota Only)
    Last Post: 7th June 2010, 12:42 PM
