Results 1 to 10 of 10
Thread: ke70 snapped axle removal help!
    ryan
    Default ke70 snapped axle removal help!
    Car - ke70
    motor / part in question - diff axle
    problem - finding it hard to remove snapped off piece
    hey guys
    Was having too much fun the other night and an axle let go. Is there anyway of taking the broken off axle piece out, without taking the diff centre out? and if you have to remove the diff centre to get it out, is there any special procedure when putting centre back in? ie seating the gears with the right amount of back lash or something like that?
    Any help is much appreciated as am trying to get the car back and running for an event this saturday.
    Ryan
    Glenn ke_70's Avatar
    Clay
    Barossa!
    you'll have hard time trying to get it out without the centre out.
    diff will go back in the same way.
    Veteran johl's Avatar
    Johl
    you will want to check all the metal is out of the centre anyway so it will have to come out. its all pretty straight forward
    Veteran maxhag's Avatar
    JoJo
    ACT
    Tuggeranong
    Quote Originally Posted by johl View Post
    ^^ Was going to say the same thing. There my be some metal fragments in there, so you want to get any shit out....
    Are you asking about removing the complete centre from the main diff housing? Or on how to remove the LSD centre from the snout housing?
    Which diff is it? Borgwonka or Toyota T series? The toyota diffs are easy and simple. The Borgwonkas can be a bit more complicated and a pain in the ass....
    Veteran willa's Avatar
    Will
    Northern 'burbs
    Tent pole or broom handle with a decent magnet attached works a treat.
    Veteran lolwat's Avatar
    Michael
    Crimebrook 2749
    dont pull the centre out, its a #### to get back in with the preload washers and shit with out using a big housing spreader, get yours self a peice of flat bar and bend the #### and smack it with a hammer
    where abouts do you live?
    ryan
    Quote Originally Posted by maxhag View Post
    i was going to take the diff centre out but as lolwut said, getting it back in with the shims will be a bitch. will just take it to a diff shop and get them to take it and the spider gear pin out as well. so next time i can just bash a pole through the other side to get the piece out. its a borg warner not a t series.
    Quote Originally Posted by willa View Post
    havent managed to get the piece out of the centre yet and its stuck in there pretty good, don't think any normal magnet will get it out.
    Quote Originally Posted by lolwat View Post
    dw i wont be attempting it myself, will take it to a diff place.
    Hair model Jacobxxx's Avatar
    Jacob
    Bangalow
    borgy? put a new diff in
    Veteran stahlz_ae86's Avatar
    Paul
    Lol at this, I helped a guy that lives up the street last week to get a piece of spline out of the borgy in his VL. He tried using tent poles and got that jammed in there making it even more difficult to remove. I used a bit of 12mm bar and trimmed the end to get past the pin in the middle of the diff centre.
    Will
    Northern 'burbs
    Quote Originally Posted by stahlz_ae86 View Post
    Lolol! Look personally I've never done it, but heard from a few different people it works. Guess it depends how it snaps?
    The VL was his main problem :p
  1. Wtb ke70 axle
    By KE70-JACK in forum Perth & WA Events and Discussion
    Last Post: 25th November 2012, 09:06 PM
  2. Bent axle removal
    By dogan in forum Technical - Questions
    Last Post: 24th September 2012, 06:22 PM
  3. F series diff axle removal
    By AE86 Spoontah in forum Technical - Questions
    Last Post: 8th June 2012, 08:43 AM
  4. removing snapped axle skillzzz
    Last Post: 24th January 2009, 01:22 AM
  5. help with axle removal
    By gaz20v in forum Technical - Questions
    Last Post: 23rd March 2008, 12:51 PM
